2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+1 | |
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 2 | -7/+6 | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+2 | |
adds .cvsignore. | |||||
2000-01-31 | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | |||||
1999-11-23 | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+45 | |
to convert the tmtests directory from Makefile.in to Makefile.am. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 3 | -6/+3 | |
1999-11-02 | Backed out change that increased the minimum stack size since it | Joel Sherrill | 1 | -1/+0 | |
was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme. | |||||
1999-11-01 | Increased stack space for all initialization tasks in tmtests. | Joel Sherrill | 1 | -0/+1 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 3 | -3/+3 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 3 | -6/+6 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 3 | -15/+15 | |
of switching to the modified GNU GPL. | |||||
1996-05-30 | tests now specify whether they are using rtems initialization tasks | Joel Sherrill | 1 | -0/+2 | |
or posix initialization threads | |||||
1995-12-20 | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1 | -2/+2 | |
partially recovered working tree, etc | |||||
1995-09-19 | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1 | -2/+2 | |
single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | |||||
1995-09-11 | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 2 | -5/+24 | |
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
1995-08-23 | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1 | -1/+1 | |
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | |||||
1995-08-17 | maximum number of messages removed and include statement cleanup | Joel Sherrill | 1 | -7/+5 | |
