path: root/testsuites/tmtests/tm22 (follow)
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am: Reformat. * tm01/Makefile.am: Remove all-local: $(ARCH). * tm02/Makefile.am: Remove all-local: $(ARCH). * tm03/Makefile.am: Remove all-local: $(ARCH). * tm04/Makefile.am: Remove all-local: $(ARCH). * tm05/Makefile.am: Remove all-local: $(ARCH). * tm06/Makefile.am: Remove all-local: $(ARCH). * tm07/Makefile.am: Remove all-local: $(ARCH). * tm08/Makefile.am: Remove all-local: $(ARCH). * tm09/Makefile.am: Remove all-local: $(ARCH). * tm10/Makefile.am: Remove all-local: $(ARCH). * tm11/Makefile.am: Remove all-local: $(ARCH). * tm12/Makefile.am: Remove all-local: $(ARCH). * tm13/Makefile.am: Remove all-local: $(ARCH). * tm14/Makefile.am: Remove all-local: $(ARCH). * tm15/Makefile.am: Remove all-local: $(ARCH). * tm16/Makefile.am: Remove all-local: $(ARCH). * tm17/Makefile.am: Remove all-local: $(ARCH). * tm18/Makefile.am: Remove all-local: $(ARCH). * tm19/Makefile.am: Remove all-local: $(ARCH). * tm20/Makefile.am: Remove all-local: $(ARCH). * tm21/Makefile.am: Remove all-local: $(ARCH). * tm22/Makefile.am: Remove all-local: $(ARCH). * tm23/Makefile.am: Remove all-local: $(ARCH). * tm24/Makefile.am: Remove all-local: $(ARCH). * tm25/Makefile.am: Remove all-local: $(ARCH). * tm26/Makefile.am: Remove all-local: $(ARCH). * tm27/Makefile.am: Remove all-local: $(ARCH). * tm28/Makefile.am: Remove all-local: $(ARCH). * tm29/Makefile.am: Remove all-local: $(ARCH). * tmck/Makefile.am: Remove all-local: $(ARCH). * tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-043-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc, tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h, tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c, tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc, tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h, tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c, tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc, tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h, tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c, tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc, tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h, tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c, tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc, tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h, tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c, tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc, tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h, tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c, tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc, tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc, tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h, tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c, tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc, tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h, tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tm01/Makefile.am: Reflect having moved automake. tm02/Makefile.am: Reflect having moved automake. tm03/Makefile.am: Reflect having moved automake. tm04/Makefile.am: Reflect having moved automake. tm05/Makefile.am: Reflect having moved automake. tm06/Makefile.am: Reflect having moved automake. tm07/Makefile.am: Reflect having moved automake. tm08/Makefile.am: Reflect having moved automake. tm09/Makefile.am: Reflect having moved automake. tm10/Makefile.am: Reflect having moved automake. tm11/Makefile.am: Reflect having moved automake. tm12/Makefile.am: Reflect having moved automake. tm13/Makefile.am: Reflect having moved automake. tm14/Makefile.am: Reflect having moved automake. tm15/Makefile.am: Reflect having moved automake. tm16/Makefile.am: Reflect having moved automake. tm17/Makefile.am: Reflect having moved automake. tm18/Makefile.am: Reflect having moved automake. tm19/Makefile.am: Reflect having moved automake. tm20/Makefile.am: Reflect having moved automake. tm21/Makefile.am: Reflect having moved automake. tm22/Makefile.am: Reflect having moved automake. tm23/Makefile.am: Reflect having moved automake. tm24/Makefile.am: Reflect having moved automake. tm25/Makefile.am: Reflect having moved automake. tm26/Makefile.am: Reflect having moved automake. tm27/Makefile.am: Reflect having moved automake. tm28/Makefile.am: Reflect having moved automake. tm29/Makefile.am: Reflect having moved automake. tmck/Makefile.am: Reflect having moved automake. tmoverhd/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am: Use $(OBJEXT) instead of .o. * tm02/Makefile.am: Use $(OBJEXT) instead of .o. * tm03/Makefile.am: Use $(OBJEXT) instead of .o. * tm04/Makefile.am: Use $(OBJEXT) instead of .o. * tm05/Makefile.am: Use $(OBJEXT) instead of .o. * tm06/Makefile.am: Use $(OBJEXT) instead of .o. * tm07/Makefile.am: Use $(OBJEXT) instead of .o. * tm08/Makefile.am: Use $(OBJEXT) instead of .o. * tm09/Makefile.am: Use $(OBJEXT) instead of .o. * tm10/Makefile.am: Use $(OBJEXT) instead of .o. * tm11/Makefile.am: Use $(OBJEXT) instead of .o. * tm12/Makefile.am: Use $(OBJEXT) instead of .o. * tm13/Makefile.am: Use $(OBJEXT) instead of .o. * tm14/Makefile.am: Use $(OBJEXT) instead of .o. * tm15/Makefile.am: Use $(OBJEXT) instead of .o. * tm16/Makefile.am: Use $(OBJEXT) instead of .o. * tm17/Makefile.am: Use $(OBJEXT) instead of .o. * tm18/Makefile.am: Use $(OBJEXT) instead of .o. * tm19/Makefile.am: Use $(OBJEXT) instead of .o. * tm20/Makefile.am: Use $(OBJEXT) instead of .o. * tm21/Makefile.am: Use $(OBJEXT) instead of .o. * tm22/Makefile.am: Use $(OBJEXT) instead of .o. * tm23/Makefile.am: Use $(OBJEXT) instead of .o. * tm24/Makefile.am: Use $(OBJEXT) instead of .o. * tm25/Makefile.am: Use $(OBJEXT) instead of .o. * tm26/Makefile.am: Use $(OBJEXT) instead of .o. * tm27/Makefile.am: Use $(OBJEXT) instead of .o. * tm28/Makefile.am: Use $(OBJEXT) instead of .o. * tm29/Makefile.am: Use $(OBJEXT) instead of .o. * tmck/Makefile.am: Use $(OBJEXT) instead of .o. * tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+1
| | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tm01/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm02/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm03/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm04/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm05/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm06/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm07/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm08/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm09/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm10/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm11/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm12/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm13/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm14/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm15/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm16/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm17/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm18/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm19/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm20/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm21/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm22/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm23/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm24/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm25/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm26/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm27/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm28/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm29/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmck/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-14/+15
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+45
| | | | to convert the tmtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-3/+3
| | | | partially recovered working tree, etc
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+25
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-2/+2
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-172-9/+14
* Initial revisionJoel Sherrill1995-05-113-0/+229
