path: root/testsuites/tmtests/tm20/system.h (follow)
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+22
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-7/+5
* Initial revisionJoel Sherrill1995-05-111-0/+23
