path: root/testsuites/tmtests/tm18 (follow)
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-1/+1
| | | | partially recovered working tree, etc
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+25
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-7/+5
* Initial revisionJoel Sherrill1995-05-113-0/+148
