path: root/testsuites/tmtests/tm13 (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-9/+10
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+45
| | | | to convert the tmtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-1/+1
| | | | partially recovered working tree, etc
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+25
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-2/+2
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-172-10/+15
* Initial revisionJoel Sherrill1995-05-113-0/+183
