path: root/testsuites/tmtests/tm10 (follow)
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+6
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+45
| | | | to convert the tmtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-2/+2
| | | | partially recovered working tree, etc
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+25
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-2/+2
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-172-8/+15
* Initial revisionJoel Sherrill1995-05-113-0/+192
