path: root/testsuites/tmtests/tm05 (follow)
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | PR 1589/build * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* Add missing prototypes.Ralf Corsepius2009-10-261-2/+2
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-8/+12
| | | | | | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-312-5/+6
| | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c, tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c, tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c, tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c, tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c, tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c, tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c, tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c, tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c, tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c, tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c, tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c, tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c, tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c, tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c, tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
* 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-08-311-4/+4
| | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS programming conventions.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-011-1/+1
| | | | | | | | | | | | * tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-111-1/+1
| | | | | | | | | | | | | | * tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-2/+1
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-12/+8
* Rework.Ralf Corsepius2005-11-111-22/+6
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Eliminate TEST.Ralf Corsepius2005-11-111-5/+4
* Expand tmtests.am.Ralf Corsepius2005-11-111-1/+13
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* Add ../include/systime.hRalf Corsepius2005-11-081-1/+1
* CleanupRalf Corsepius2005-11-071-3/+1
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-8/+7
* Remove stray white spaces.Ralf Corsepius2004-04-201-2/+2
* * tm01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* 2004-03-30 David Querbach <querbach@realtime.bc.ca>Joel Sherrill2004-03-301-3/+1
| | | | | | | | | | | | | | | PR 597/tests * tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h, tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h, tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h, tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h, tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h, tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h, tm27/task1.c, tm29/system.h: The actual workspace needed by the tmtests depends on OPERATION_COUNT, but the definitions of CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect this. This results in unnecessary memory exhaustion on small-memory systems such as the SS555.
* 2004-03-28 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-281-2/+2
| | | | | | | | | | | | * include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using c99 fixed size types.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * tm02/Makefile.am: Ditto. * tm03/Makefile.am: Ditto. * tm04/Makefile.am: Ditto. * tm05/Makefile.am: Ditto. * tm06/Makefile.am: Ditto. * tm07/Makefile.am: Ditto. * tm08/Makefile.am: Ditto. * tm09/Makefile.am: Ditto. * tm10/Makefile.am: Ditto. * tm11/Makefile.am: Ditto. * tm12/Makefile.am: Ditto. * tm13/Makefile.am: Ditto. * tm14/Makefile.am: Ditto. * tm15/Makefile.am: Ditto. * tm16/Makefile.am: Ditto. * tm17/Makefile.am: Ditto. * tm18/Makefile.am: Ditto. * tm19/Makefile.am: Ditto. * tm20/Makefile.am: Ditto. * tm21/Makefile.am: Ditto. * tm22/Makefile.am: Ditto. * tm23/Makefile.am: Ditto. * tm24/Makefile.am: Ditto. * tm25/Makefile.am: Ditto. * tm26/Makefile.am: Ditto. * tm27/Makefile.am: Ditto. * tm28/Makefile.am: Ditto. * tm29/Makefile.am: Ditto. * tmck/Makefile.am: Ditto. * tmoverhd/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am: Reformat. * tm01/Makefile.am: Remove all-local: $(ARCH). * tm02/Makefile.am: Remove all-local: $(ARCH). * tm03/Makefile.am: Remove all-local: $(ARCH). * tm04/Makefile.am: Remove all-local: $(ARCH). * tm05/Makefile.am: Remove all-local: $(ARCH). * tm06/Makefile.am: Remove all-local: $(ARCH). * tm07/Makefile.am: Remove all-local: $(ARCH). * tm08/Makefile.am: Remove all-local: $(ARCH). * tm09/Makefile.am: Remove all-local: $(ARCH). * tm10/Makefile.am: Remove all-local: $(ARCH). * tm11/Makefile.am: Remove all-local: $(ARCH). * tm12/Makefile.am: Remove all-local: $(ARCH). * tm13/Makefile.am: Remove all-local: $(ARCH). * tm14/Makefile.am: Remove all-local: $(ARCH). * tm15/Makefile.am: Remove all-local: $(ARCH). * tm16/Makefile.am: Remove all-local: $(ARCH). * tm17/Makefile.am: Remove all-local: $(ARCH). * tm18/Makefile.am: Remove all-local: $(ARCH). * tm19/Makefile.am: Remove all-local: $(ARCH). * tm20/Makefile.am: Remove all-local: $(ARCH). * tm21/Makefile.am: Remove all-local: $(ARCH). * tm22/Makefile.am: Remove all-local: $(ARCH). * tm23/Makefile.am: Remove all-local: $(ARCH). * tm24/Makefile.am: Remove all-local: $(ARCH). * tm25/Makefile.am: Remove all-local: $(ARCH). * tm26/Makefile.am: Remove all-local: $(ARCH). * tm27/Makefile.am: Remove all-local: $(ARCH). * tm28/Makefile.am: Remove all-local: $(ARCH). * tm29/Makefile.am: Remove all-local: $(ARCH). * tmck/Makefile.am: Remove all-local: $(ARCH). * tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-043-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc, tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h, tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c, tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc, tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h, tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c, tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc, tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h, tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c, tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc, tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h, tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c, tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc, tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h, tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c, tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc, tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h, tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c, tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc, tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc, tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h, tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c, tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc, tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h, tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tm01/Makefile.am: Reflect having moved automake. tm02/Makefile.am: Reflect having moved automake. tm03/Makefile.am: Reflect having moved automake. tm04/Makefile.am: Reflect having moved automake. tm05/Makefile.am: Reflect having moved automake. tm06/Makefile.am: Reflect having moved automake. tm07/Makefile.am: Reflect having moved automake. tm08/Makefile.am: Reflect having moved automake. tm09/Makefile.am: Reflect having moved automake. tm10/Makefile.am: Reflect having moved automake. tm11/Makefile.am: Reflect having moved automake. tm12/Makefile.am: Reflect having moved automake. tm13/Makefile.am: Reflect having moved automake. tm14/Makefile.am: Reflect having moved automake. tm15/Makefile.am: Reflect having moved automake. tm16/Makefile.am: Reflect having moved automake. tm17/Makefile.am: Reflect having moved automake. tm18/Makefile.am: Reflect having moved automake. tm19/Makefile.am: Reflect having moved automake. tm20/Makefile.am: Reflect having moved automake. tm21/Makefile.am: Reflect having moved automake. tm22/Makefile.am: Reflect having moved automake. tm23/Makefile.am: Reflect having moved automake. tm24/Makefile.am: Reflect having moved automake. tm25/Makefile.am: Reflect having moved automake. tm26/Makefile.am: Reflect having moved automake. tm27/Makefile.am: Reflect having moved automake. tm28/Makefile.am: Reflect having moved automake. tm29/Makefile.am: Reflect having moved automake. tmck/Makefile.am: Reflect having moved automake. tmoverhd/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am: Use $(OBJEXT) instead of .o. * tm02/Makefile.am: Use $(OBJEXT) instead of .o. * tm03/Makefile.am: Use $(OBJEXT) instead of .o. * tm04/Makefile.am: Use $(OBJEXT) instead of .o. * tm05/Makefile.am: Use $(OBJEXT) instead of .o. * tm06/Makefile.am: Use $(OBJEXT) instead of .o. * tm07/Makefile.am: Use $(OBJEXT) instead of .o. * tm08/Makefile.am: Use $(OBJEXT) instead of .o. * tm09/Makefile.am: Use $(OBJEXT) instead of .o. * tm10/Makefile.am: Use $(OBJEXT) instead of .o. * tm11/Makefile.am: Use $(OBJEXT) instead of .o. * tm12/Makefile.am: Use $(OBJEXT) instead of .o. * tm13/Makefile.am: Use $(OBJEXT) instead of .o. * tm14/Makefile.am: Use $(OBJEXT) instead of .o. * tm15/Makefile.am: Use $(OBJEXT) instead of .o. * tm16/Makefile.am: Use $(OBJEXT) instead of .o. * tm17/Makefile.am: Use $(OBJEXT) instead of .o. * tm18/Makefile.am: Use $(OBJEXT) instead of .o. * tm19/Makefile.am: Use $(OBJEXT) instead of .o. * tm20/Makefile.am: Use $(OBJEXT) instead of .o. * tm21/Makefile.am: Use $(OBJEXT) instead of .o. * tm22/Makefile.am: Use $(OBJEXT) instead of .o. * tm23/Makefile.am: Use $(OBJEXT) instead of .o. * tm24/Makefile.am: Use $(OBJEXT) instead of .o. * tm25/Makefile.am: Use $(OBJEXT) instead of .o. * tm26/Makefile.am: Use $(OBJEXT) instead of .o. * tm27/Makefile.am: Use $(OBJEXT) instead of .o. * tm28/Makefile.am: Use $(OBJEXT) instead of .o. * tm29/Makefile.am: Use $(OBJEXT) instead of .o. * tmck/Makefile.am: Use $(OBJEXT) instead of .o. * tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+1
| | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tm01/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm02/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm03/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm04/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm05/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm06/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm07/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm08/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm09/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm10/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm11/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm12/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm13/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm14/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm15/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm16/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm17/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm18/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm19/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm20/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm21/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm22/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm23/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm24/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm25/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm26/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm27/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm28/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm29/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmck/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+6
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+45
| | | | to convert the tmtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether they are using rtems initialization tasksJoel Sherrill1996-05-301-0/+2
| | | | or posix initialization threads
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-2/+2
| | | | partially recovered working tree, etc
