for details.
PR 1589/build
* tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am,
tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am,
tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am,
tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am,
tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am,
tm28/Makefile.am, tm29/Makefile.am, tm30/Makefile.am,
tmck/Makefile.am, tmoverhd/Makefile.am: Remove obsolete optional
manager capability.
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm16/task1.c,
tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c,
tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c,
tm28/task1.c, tm29/task1.c, tmoverhd/testtask.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
from every benchmark timer driver. Fix spelling.
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
programming conventions.
tmoverhd/testtask.c: Change TEST_INIT to CONFIGURE_INIT. Make
tmacros.h available to all POSIX tests. Add a clock_settime case for
< 1988.
* tm02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm18/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm27/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm28/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tm29/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmck/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* tmoverhd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
PR 597/tests
* tm02/system.h, tm03/system.h, tm04/system.h, tm05/system.h,
tm06/system.h, tm07/system.h, tm08/system.h, tm10/system.h,
tm11/system.h, tm12/system.h, tm13/system.h, tm14/system.h,
tm15/system.h, tm16/system.h, tm17/system.h, tm18/system.h,
tm19/system.h, tm21/system.h, tm22/system.h, tm23/system.h,
tm24/system.h, tm25/system.h, tm26/system.h, tm27/system.h,
tm27/task1.c, tm29/system.h: The actual workspace needed by the
tmtests depends on OPERATION_COUNT, but the definitions of
CONFIGURE_MAXIMIM_xxx in the their system.h files do not reflect
this. This results in unnecessary memory exhaustion on small-memory
systems such as the SS555.
* include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c,
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c,
tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm20/task1.c,
tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Convert to using
c99 fixed size types.
* tm01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tm02/Makefile.am: Ditto.
* tm03/Makefile.am: Ditto.
* tm04/Makefile.am: Ditto.
* tm05/Makefile.am: Ditto.
* tm06/Makefile.am: Ditto.
* tm07/Makefile.am: Ditto.
* tm08/Makefile.am: Ditto.
* tm09/Makefile.am: Ditto.
* tm10/Makefile.am: Ditto.
* tm11/Makefile.am: Ditto.
* tm12/Makefile.am: Ditto.
* tm13/Makefile.am: Ditto.
* tm14/Makefile.am: Ditto.
* tm15/Makefile.am: Ditto.
* tm16/Makefile.am: Ditto.
* tm17/Makefile.am: Ditto.
* tm18/Makefile.am: Ditto.
* tm19/Makefile.am: Ditto.
* tm20/Makefile.am: Ditto.
* tm21/Makefile.am: Ditto.
* tm22/Makefile.am: Ditto.
* tm23/Makefile.am: Ditto.
* tm24/Makefile.am: Ditto.
* tm25/Makefile.am: Ditto.
* tm26/Makefile.am: Ditto.
* tm27/Makefile.am: Ditto.
* tm28/Makefile.am: Ditto.
* tm29/Makefile.am: Ditto.
* tmck/Makefile.am: Ditto.
* tmoverhd/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* tm01/Makefile.am: Remove all-local: $(ARCH).
* tm02/Makefile.am: Remove all-local: $(ARCH).
* tm03/Makefile.am: Remove all-local: $(ARCH).
* tm04/Makefile.am: Remove all-local: $(ARCH).
* tm05/Makefile.am: Remove all-local: $(ARCH).
* tm06/Makefile.am: Remove all-local: $(ARCH).
* tm07/Makefile.am: Remove all-local: $(ARCH).
* tm08/Makefile.am: Remove all-local: $(ARCH).
* tm09/Makefile.am: Remove all-local: $(ARCH).
* tm10/Makefile.am: Remove all-local: $(ARCH).
* tm11/Makefile.am: Remove all-local: $(ARCH).
* tm12/Makefile.am: Remove all-local: $(ARCH).
* tm13/Makefile.am: Remove all-local: $(ARCH).
* tm14/Makefile.am: Remove all-local: $(ARCH).
* tm15/Makefile.am: Remove all-local: $(ARCH).
* tm16/Makefile.am: Remove all-local: $(ARCH).
* tm17/Makefile.am: Remove all-local: $(ARCH).
* tm18/Makefile.am: Remove all-local: $(ARCH).
* tm19/Makefile.am: Remove all-local: $(ARCH).
* tm20/Makefile.am: Remove all-local: $(ARCH).
* tm21/Makefile.am: Remove all-local: $(ARCH).
* tm22/Makefile.am: Remove all-local: $(ARCH).
* tm23/Makefile.am: Remove all-local: $(ARCH).
* tm24/Makefile.am: Remove all-local: $(ARCH).
* tm25/Makefile.am: Remove all-local: $(ARCH).
* tm26/Makefile.am: Remove all-local: $(ARCH).
* tm27/Makefile.am: Remove all-local: $(ARCH).
* tm28/Makefile.am: Remove all-local: $(ARCH).
* tm29/Makefile.am: Remove all-local: $(ARCH).
* tmck/Makefile.am: Remove all-local: $(ARCH).
* tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc,
tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h,
tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c,
tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc,
tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h,
tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c,
tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc,
tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h,
tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c,
tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc,
tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h,
tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c,
tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc,
tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h,
tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c,
tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc,
tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h,
tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c,
tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc,
tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc,
tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h,
tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c,
tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc,
tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h,
tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
* tm01/Makefile.am: Use $(OBJEXT) instead of .o.
* tm02/Makefile.am: Use $(OBJEXT) instead of .o.
* tm03/Makefile.am: Use $(OBJEXT) instead of .o.
* tm04/Makefile.am: Use $(OBJEXT) instead of .o.
* tm05/Makefile.am: Use $(OBJEXT) instead of .o.
* tm06/Makefile.am: Use $(OBJEXT) instead of .o.
* tm07/Makefile.am: Use $(OBJEXT) instead of .o.
* tm08/Makefile.am: Use $(OBJEXT) instead of .o.
* tm09/Makefile.am: Use $(OBJEXT) instead of .o.
* tm10/Makefile.am: Use $(OBJEXT) instead of .o.
* tm11/Makefile.am: Use $(OBJEXT) instead of .o.
* tm12/Makefile.am: Use $(OBJEXT) instead of .o.
* tm13/Makefile.am: Use $(OBJEXT) instead of .o.
* tm14/Makefile.am: Use $(OBJEXT) instead of .o.
* tm15/Makefile.am: Use $(OBJEXT) instead of .o.
* tm16/Makefile.am: Use $(OBJEXT) instead of .o.
* tm17/Makefile.am: Use $(OBJEXT) instead of .o.
* tm18/Makefile.am: Use $(OBJEXT) instead of .o.
* tm19/Makefile.am: Use $(OBJEXT) instead of .o.
* tm20/Makefile.am: Use $(OBJEXT) instead of .o.
* tm21/Makefile.am: Use $(OBJEXT) instead of .o.
* tm22/Makefile.am: Use $(OBJEXT) instead of .o.
* tm23/Makefile.am: Use $(OBJEXT) instead of .o.
* tm24/Makefile.am: Use $(OBJEXT) instead of .o.
* tm25/Makefile.am: Use $(OBJEXT) instead of .o.
* tm26/Makefile.am: Use $(OBJEXT) instead of .o.
* tm27/Makefile.am: Use $(OBJEXT) instead of .o.
* tm28/Makefile.am: Use $(OBJEXT) instead of .o.
* tm29/Makefile.am: Use $(OBJEXT) instead of .o.
* tmck/Makefile.am: Use $(OBJEXT) instead of .o.
* tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c,
tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c,
tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c,
tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c,
tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c,
tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: include leaf.am instead of leaf.cfg.
* tm26/Makefile.am: include leaf.am instead of leaf.cfg.
* tm24/Makefile.am: include leaf.am instead of leaf.cfg.
* tm16/Makefile.am: include leaf.am instead of leaf.cfg.
* tm18/Makefile.am: include leaf.am instead of leaf.cfg.
* tm02/Makefile.am: include leaf.am instead of leaf.cfg.
* tm10/Makefile.am: include leaf.am instead of leaf.cfg.
* tm11/Makefile.am: include leaf.am instead of leaf.cfg.
* tm15/Makefile.am: include leaf.am instead of leaf.cfg.
* tm19/Makefile.am: include leaf.am instead of leaf.cfg.
* tm04/Makefile.am: include leaf.am instead of leaf.cfg.
* tm17/Makefile.am: include leaf.am instead of leaf.cfg.
* tm28/Makefile.am: include leaf.am instead of leaf.cfg.
* tmck/Makefile.am: include leaf.am instead of leaf.cfg.
* tm08/Makefile.am: include leaf.am instead of leaf.cfg.
* tm12/Makefile.am: include leaf.am instead of leaf.cfg.
* tm03/Makefile.am: include leaf.am instead of leaf.cfg.
* tm13/Makefile.am: include leaf.am instead of leaf.cfg.
* tm29/Makefile.am: include leaf.am instead of leaf.cfg.
* tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg.
* tm20/Makefile.am: include leaf.am instead of leaf.cfg.
* tm09/Makefile.am: include leaf.am instead of leaf.cfg.
* tm01/Makefile.am: include leaf.am instead of leaf.cfg.
* tm21/Makefile.am: include leaf.am instead of leaf.cfg.
* tm07/Makefile.am: include leaf.am instead of leaf.cfg.
* tm25/Makefile.am: include leaf.am instead of leaf.cfg.
* tm22/Makefile.am: include leaf.am instead of leaf.cfg.
* tm06/Makefile.am: include leaf.am instead of leaf.cfg.
* tm05/Makefile.am: include leaf.am instead of leaf.cfg.
* tm14/Makefile.am: include leaf.am instead of leaf.cfg.
* tm23/Makefile.am: include leaf.am instead of leaf.cfg.
tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Include compile.am
to convert the tmtests directory from Makefile.in to Makefile.am.
was unnecessary. The real fix was an alignment error in the
object extend memory allocation scheme.
or posix initialization threads
