path: root/testsuites/tmtests/tm02 (follow)
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am: Reformat. * tm01/Makefile.am: Remove all-local: $(ARCH). * tm02/Makefile.am: Remove all-local: $(ARCH). * tm03/Makefile.am: Remove all-local: $(ARCH). * tm04/Makefile.am: Remove all-local: $(ARCH). * tm05/Makefile.am: Remove all-local: $(ARCH). * tm06/Makefile.am: Remove all-local: $(ARCH). * tm07/Makefile.am: Remove all-local: $(ARCH). * tm08/Makefile.am: Remove all-local: $(ARCH). * tm09/Makefile.am: Remove all-local: $(ARCH). * tm10/Makefile.am: Remove all-local: $(ARCH). * tm11/Makefile.am: Remove all-local: $(ARCH). * tm12/Makefile.am: Remove all-local: $(ARCH). * tm13/Makefile.am: Remove all-local: $(ARCH). * tm14/Makefile.am: Remove all-local: $(ARCH). * tm15/Makefile.am: Remove all-local: $(ARCH). * tm16/Makefile.am: Remove all-local: $(ARCH). * tm17/Makefile.am: Remove all-local: $(ARCH). * tm18/Makefile.am: Remove all-local: $(ARCH). * tm19/Makefile.am: Remove all-local: $(ARCH). * tm20/Makefile.am: Remove all-local: $(ARCH). * tm21/Makefile.am: Remove all-local: $(ARCH). * tm22/Makefile.am: Remove all-local: $(ARCH). * tm23/Makefile.am: Remove all-local: $(ARCH). * tm24/Makefile.am: Remove all-local: $(ARCH). * tm25/Makefile.am: Remove all-local: $(ARCH). * tm26/Makefile.am: Remove all-local: $(ARCH). * tm27/Makefile.am: Remove all-local: $(ARCH). * tm28/Makefile.am: Remove all-local: $(ARCH). * tm29/Makefile.am: Remove all-local: $(ARCH). * tmck/Makefile.am: Remove all-local: $(ARCH). * tmoverhd/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-043-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/timesys.h, tm01/system.h, tm01/task1.c, tm01/tm01.doc, tm02/system.h, tm02/task1.c, tm02/tm02.doc, tm03/system.h, tm03/task1.c, tm03/tm03.doc, tm04/system.h, tm04/task1.c, tm04/tm04.doc, tm05/system.h, tm05/task1.c, tm05/tm05.doc, tm06/system.h, tm06/task1.c, tm06/tm06.doc, tm07/system.h, tm07/task1.c, tm07/tm07.doc, tm08/system.h, tm08/task1.c, tm08/tm08.doc, tm09/system.h, tm09/task1.c, tm09/tm09.doc, tm10/system.h, tm10/task1.c, tm10/tm10.doc, tm11/system.h, tm11/task1.c, tm11/tm11.doc, tm12/system.h, tm12/task1.c, tm12/tm12.doc, tm13/system.h, tm13/task1.c, tm13/tm13.doc, tm14/system.h, tm14/task1.c, tm14/tm14.doc, tm15/system.h, tm15/task1.c, tm15/tm15.doc, tm16/system.h, tm16/task1.c, tm16/tm16.doc, tm17/system.h, tm17/task1.c, tm17/tm17.doc, tm18/system.h, tm18/task1.c, tm18/tm18.doc, tm19/system.h, tm19/task1.c, tm19/tm19.doc, tm20/system.h, tm20/task1.c, tm20/tm20.doc, tm21/system.h, tm21/task1.c, tm21/tm21.doc, tm22/system.h, tm22/task1.c, tm22/tm22.doc, tm23/system.h, tm23/task1.c, tm23/tm23.doc, tm24/system.h, tm24/task1.c, tm24/tm24.doc, tm25/system.h, tm25/task1.c, tm25/tm25.doc, tm26/fptest.h, tm26/system.h, tm26/task1.c, tm26/tm26.doc, tm27/system.h, tm27/task1.c, tm27/tm27.doc, tm28/system.h, tm28/task1.c, tm28/tm28.doc, tm29/system.h, tm29/task1.c, tm29/tm29.doc, tmck/system.h, tmck/task1.c, tmck/tmck.doc, tmoverhd/dumrtems.h, tmoverhd/empty.c, tmoverhd/system.h, tmoverhd/testtask.c, tmoverhd/tmoverhd.doc: URL for license changed.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tm01/Makefile.am: Reflect having moved automake. tm02/Makefile.am: Reflect having moved automake. tm03/Makefile.am: Reflect having moved automake. tm04/Makefile.am: Reflect having moved automake. tm05/Makefile.am: Reflect having moved automake. tm06/Makefile.am: Reflect having moved automake. tm07/Makefile.am: Reflect having moved automake. tm08/Makefile.am: Reflect having moved automake. tm09/Makefile.am: Reflect having moved automake. tm10/Makefile.am: Reflect having moved automake. tm11/Makefile.am: Reflect having moved automake. tm12/Makefile.am: Reflect having moved automake. tm13/Makefile.am: Reflect having moved automake. tm14/Makefile.am: Reflect having moved automake. tm15/Makefile.am: Reflect having moved automake. tm16/Makefile.am: Reflect having moved automake. tm17/Makefile.am: Reflect having moved automake. tm18/Makefile.am: Reflect having moved automake. tm19/Makefile.am: Reflect having moved automake. tm20/Makefile.am: Reflect having moved automake. tm21/Makefile.am: Reflect having moved automake. tm22/Makefile.am: Reflect having moved automake. tm23/Makefile.am: Reflect having moved automake. tm24/Makefile.am: Reflect having moved automake. tm25/Makefile.am: Reflect having moved automake. tm26/Makefile.am: Reflect having moved automake. tm27/Makefile.am: Reflect having moved automake. tm28/Makefile.am: Reflect having moved automake. tm29/Makefile.am: Reflect having moved automake. tmck/Makefile.am: Reflect having moved automake. tmoverhd/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm01/Makefile.am: Use $(OBJEXT) instead of .o. * tm02/Makefile.am: Use $(OBJEXT) instead of .o. * tm03/Makefile.am: Use $(OBJEXT) instead of .o. * tm04/Makefile.am: Use $(OBJEXT) instead of .o. * tm05/Makefile.am: Use $(OBJEXT) instead of .o. * tm06/Makefile.am: Use $(OBJEXT) instead of .o. * tm07/Makefile.am: Use $(OBJEXT) instead of .o. * tm08/Makefile.am: Use $(OBJEXT) instead of .o. * tm09/Makefile.am: Use $(OBJEXT) instead of .o. * tm10/Makefile.am: Use $(OBJEXT) instead of .o. * tm11/Makefile.am: Use $(OBJEXT) instead of .o. * tm12/Makefile.am: Use $(OBJEXT) instead of .o. * tm13/Makefile.am: Use $(OBJEXT) instead of .o. * tm14/Makefile.am: Use $(OBJEXT) instead of .o. * tm15/Makefile.am: Use $(OBJEXT) instead of .o. * tm16/Makefile.am: Use $(OBJEXT) instead of .o. * tm17/Makefile.am: Use $(OBJEXT) instead of .o. * tm18/Makefile.am: Use $(OBJEXT) instead of .o. * tm19/Makefile.am: Use $(OBJEXT) instead of .o. * tm20/Makefile.am: Use $(OBJEXT) instead of .o. * tm21/Makefile.am: Use $(OBJEXT) instead of .o. * tm22/Makefile.am: Use $(OBJEXT) instead of .o. * tm23/Makefile.am: Use $(OBJEXT) instead of .o. * tm24/Makefile.am: Use $(OBJEXT) instead of .o. * tm25/Makefile.am: Use $(OBJEXT) instead of .o. * tm26/Makefile.am: Use $(OBJEXT) instead of .o. * tm27/Makefile.am: Use $(OBJEXT) instead of .o. * tm28/Makefile.am: Use $(OBJEXT) instead of .o. * tm29/Makefile.am: Use $(OBJEXT) instead of .o. * tmck/Makefile.am: Use $(OBJEXT) instead of .o. * tmoverhd/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+1
| | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/timesys.h, tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c, tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c, tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c, tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c, tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c, tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c, tmoverhd/testtask.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tm01/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm02/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm03/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm04/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm05/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm06/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm07/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm08/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm09/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm10/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm11/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm12/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm13/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm14/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm15/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm16/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm17/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm18/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm19/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm20/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm21/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm22/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm23/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm24/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm25/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm26/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm27/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm28/Makefile.am: Remove AUTOMAKE_OPTIONS. * tm29/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmck/Makefile.am: Remove AUTOMAKE_OPTIONS. * tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tm27/Makefile.am: include leaf.am instead of leaf.cfg. * tm26/Makefile.am: include leaf.am instead of leaf.cfg. * tm24/Makefile.am: include leaf.am instead of leaf.cfg. * tm16/Makefile.am: include leaf.am instead of leaf.cfg. * tm18/Makefile.am: include leaf.am instead of leaf.cfg. * tm02/Makefile.am: include leaf.am instead of leaf.cfg. * tm10/Makefile.am: include leaf.am instead of leaf.cfg. * tm11/Makefile.am: include leaf.am instead of leaf.cfg. * tm15/Makefile.am: include leaf.am instead of leaf.cfg. * tm19/Makefile.am: include leaf.am instead of leaf.cfg. * tm04/Makefile.am: include leaf.am instead of leaf.cfg. * tm17/Makefile.am: include leaf.am instead of leaf.cfg. * tm28/Makefile.am: include leaf.am instead of leaf.cfg. * tmck/Makefile.am: include leaf.am instead of leaf.cfg. * tm08/Makefile.am: include leaf.am instead of leaf.cfg. * tm12/Makefile.am: include leaf.am instead of leaf.cfg. * tm03/Makefile.am: include leaf.am instead of leaf.cfg. * tm13/Makefile.am: include leaf.am instead of leaf.cfg. * tm29/Makefile.am: include leaf.am instead of leaf.cfg. * tmoverhd/Makefile.am: include leaf.am instead of leaf.cfg. * tm20/Makefile.am: include leaf.am instead of leaf.cfg. * tm09/Makefile.am: include leaf.am instead of leaf.cfg. * tm01/Makefile.am: include leaf.am instead of leaf.cfg. * tm21/Makefile.am: include leaf.am instead of leaf.cfg. * tm07/Makefile.am: include leaf.am instead of leaf.cfg. * tm25/Makefile.am: include leaf.am instead of leaf.cfg. * tm22/Makefile.am: include leaf.am instead of leaf.cfg. * tm06/Makefile.am: include leaf.am instead of leaf.cfg. * tm05/Makefile.am: include leaf.am instead of leaf.cfg. * tm14/Makefile.am: include leaf.am instead of leaf.cfg. * tm23/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | * tm01/Makefile.am, tm02/Makefile.am, tm03/Makefile.am, tm04/Makefile.am, tm05/Makefile.am, tm06/Makefile.am, tm07/Makefile.am, tm08/Makefile.am, tm09/Makefile.am, tm10/Makefile.am, tm11/Makefile.am, tm12/Makefile.am, tm13/Makefile.am, tm14/Makefile.am, tm15/Makefile.am, tm16/Makefile.am, tm17/Makefile.am, tm18/Makefile.am, tm19/Makefile.am, tm20/Makefile.am, tm21/Makefile.am, tm22/Makefile.am, tm23/Makefile.am, tm24/Makefile.am, tm25/Makefile.am, tm26/Makefile.am, tm27/Makefile.am, tm28/Makefile.am, tm29/Makefile.am, tmck/Makefile.am, tmoverhd/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+6
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+45
| | | | to convert the tmtests directory from Makefile.in to Makefile.am.
* Updated copyright notice.Joel Sherrill1999-11-173-6/+3
* Backed out change that increased the minimum stack size since itJoel Sherrill1999-11-021-1/+0
| | | | | was unnecessary. The real fix was an alignment error in the object extend memory allocation scheme.
* Increased stack space for all initialization tasks in tmtests.Joel Sherrill1999-11-011-0/+1
* updated copyright to 1998Joel Sherrill1998-02-173-3/+3
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-083-6/+6
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-1/+1
| | | | partially recovered working tree, etc
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-5/+27
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-0/+1
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-7/+5
* Initial revisionJoel Sherrill1995-05-113-0/+192
