Close #3250.
Close #4081.
Closes #4040.
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
upgrade to that version.
Close #3387.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Test run performed on T4240 running at 1667MHz in uni-processor
configuration.
Update #2554.
tm02 and tm03 were modified to be reused for multiple configurations
of RTEMS Classic API Semaphores. This added tm31-36. The messages for
tm02 and tm03 were modified to indicate the semaphore attributes.
tm31 - tm36 were added. This resulted in the following cases:
tm02 - rtems_semaphore_obtain: Counting/FIFO not available caller blocks
tm03 - rtems_semaphore_release: Counting/FIFO task readied preempts caller
tm31 - rtems_semaphore_obtain: Counting/priority not available caller blocks
tm32 - rtems_semaphore_release: Counting/priority task readied preempts caller
tm33 - rtems_semaphore_obtain: Binary/FIFO not available caller blocks
tm34 - rtems_semaphore_release: Binary/FIFO task readied preempts caller
tm35 - rtems_semaphore_obtain: Binary/priority not available caller blocks
tm36 - rtems_semaphore_release: Binary/priority task readied preempts caller
for details.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* Makefile.am, configure.ac: New test for barrier create, ident, and
delete.
* tm30/.cvsignore, tm30/Makefile.am, tm30/init.c, tm30/tm30.doc: New
files.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* configure.ac: Remove CC_CFLAGS_DEBUG_V.
CC_CFLAGS_DEFAULT (obsolete).
* configure.ac: Remove CC_CFLAGS_PROFILE_V.
Remove CC_LDFLAGS_PROFILE_V.
* tm01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm18/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tm29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmck/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmoverhd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
