* Makefile.am: Cleanup.
* tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp).
* tmitronsem01/Makefile.am:
Partial conversion to automake.
* tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>.
* include/timesys.h: Convert to using c99 fixed size types.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* tmitrontests.am: Add dirstamp support.
* tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* include/Makefile.am: Reformat.
* tmitronsem01/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h,
tmitronsem01/tmitronsem01.doc: URL for license changed.
tmitronsem01/Makefile.am: Reflect having moved automake.
* configure.ac: Remove CC_CFLAGS_DEBUG_V.
CC_CFLAGS_DEFAULT (obsolete).
* configure.ac: Remove CC_CFLAGS_PROFILE_V.
Remove CC_LDFLAGS_PROFILE_V.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* tmitronsem01/init.c: Modified.
* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* tmitrontests.am: Remove DEFS.
* tmitronsem01/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
