2006-07-11 | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | 1 | -2/+1 | |
2006-07-11 | 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead. | |||||
2005-11-22 | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -3/+5 | |
* configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | |||||
2005-11-13 | Fix my email address | Ralf Corsepius | 1 | -5/+5 | |
2005-11-13 | Convert to using *_PROGRAMS. | Ralf Corsepius | 1 | -11/+8 | |
2005-11-13 | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* tmitronsem01/Makefile.am: Convert to using *_PROGRAMS. | |||||
2005-11-11 | Fix typos. | Ralf Corsepius | 1 | -1/+1 | |
2005-11-11 | * tmitronsem01/Makefile.am: Rework. | Ralf Corsepius | 1 | -0/+4 | |
2005-11-11 | Rework. | Ralf Corsepius | 1 | -22/+6 | |
2005-11-11 | Cosmetics. | Ralf Corsepius | 1 | -3/+0 | |
2005-11-11 | Eliminate TEST. | Ralf Corsepius | 1 | -5/+4 | |
2005-11-11 | Expand tmitrontests.am. | Ralf Corsepius | 1 | -2/+13 | |
2005-11-11 | Remove. | Ralf Corsepius | 1 | -15/+0 | |
2005-11-11 | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* tmitrontests.am: Remove. * tmitronsem01/Makefile.am: Expand tmitrontests.am. | |||||
2005-11-10 | Eliminate DOCTYPES. | Ralf Corsepius | 1 | -2/+1 | |
2005-11-09 | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | 1 | -0/+2 | |
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include. | |||||
2005-11-09 | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT) | |||||
2005-11-07 | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* tmitrontests.am: Remove LIB_VARIANT. | |||||
2005-11-07 | Remove SRC, PRINT_SRC. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-07 | * tmitronsem01/Makefile.am: Remove SRC, PRINT_SRC. | Ralf Corsepius | 1 | -0/+4 | |
2005-11-07 | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 1 | -1/+1 | |
2005-11-07 | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+4 | |
* Makefile.am: Cleanup. | |||||
2005-11-07 | Add $(PGM): ${ARCH}/$(dirstamp). | Ralf Corsepius | 1 | -0/+2 | |
2005-11-07 | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp). * tmitronsem01/Makefile.am: Partial conversion to automake. | |||||
2005-11-07 | Partial conversion to automake. | Ralf Corsepius | 1 | -9/+6 | |
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-20 | Remove stray white spaces. | Ralf Corsepius | 2 | -4/+4 | |
2004-04-01 | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 2 | -1/+5 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | |||||
2004-03-30 | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* include/timesys.h: Convert to using c99 fixed size types. | |||||
2004-03-26 | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 5 | -12/+8 | |
* include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above. | |||||
2004-03-25 | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Add 2nd arg to RTEMS_TOP. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+7 | |
* tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
2003-12-18 | 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -4/+8 | |
* tmitrontests.am: Add dirstamp support. | |||||
2003-12-17 | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs). | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -3/+6 | |
* include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH). | |||||
2003-11-10 | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Reflect having moved to testsuites/. | |||||
2003-10-22 | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+4 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-02 | 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+4 | |
* configure.ac:Remove RTEMS_CHECK_CPU. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 5 | -4/+9 | |
* include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-17 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -3/+3 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -6/+12 | |
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tmitronsem01/Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-05-27 | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+5 | |
* configure.ac: Remove CC_CFLAGS_DEBUG_V. CC_CFLAGS_DEFAULT (obsolete). | |||||
* configure.ac: Remove CC_CFLAGS_PROFILE_V. Remove CC_LDFLAGS_PROFILE_V. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 2 | -1/+4 | |
