2008-08-31 | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -13/+14 | |
* tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | |||||
2008-02-01 | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* tmitronsem01/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | |||||
2006-07-11 | Eliminate scndir, docdir. Use rtems_testsdir instead. | Ralf Corsepius | 1 | -2/+1 | |
2005-11-13 | Convert to using *_PROGRAMS. | Ralf Corsepius | 1 | -11/+8 | |
2005-11-11 | Rework. | Ralf Corsepius | 1 | -22/+6 | |
2005-11-11 | Cosmetics. | Ralf Corsepius | 1 | -3/+0 | |
2005-11-11 | Eliminate TEST. | Ralf Corsepius | 1 | -5/+4 | |
2005-11-11 | Expand tmitrontests.am. | Ralf Corsepius | 1 | -2/+13 | |
2005-11-10 | Eliminate DOCTYPES. | Ralf Corsepius | 1 | -2/+1 | |
2005-11-09 | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | 1 | -0/+2 | |
2005-11-07 | Remove SRC, PRINT_SRC. | Ralf Corsepius | 1 | -2/+0 | |
2005-11-07 | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 1 | -1/+1 | |
2005-11-07 | Partial conversion to automake. | Ralf Corsepius | 1 | -9/+6 | |
2004-04-20 | Remove stray white spaces. | Ralf Corsepius | 1 | -3/+3 | |
2004-04-01 | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 1 | -1/+1 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+2 | |
* tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+1 | |
* include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH). | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -3/+3 | |
* include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed. | |||||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -3/+3 | |
Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tmitronsem01/Makefile.am: Reflect having moved automake. | |||||
2002-08-11 | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
2002-08-02 | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * tmitronsem01/init.c: Modified. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-09-19 | 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg. | |||||
2000-09-05 | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+1 | |
* tmitronsem01/Makefile.am: Include compile.am | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 2 | -6/+8 | |
2000-04-13 | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1 | -0/+2 | |
adds .cvsignore. | |||||
2000-01-31 | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | |||||
1999-11-30 | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1 | -0/+45 | |
<corsepiu@faw.uni-ulm.de> which converted fiels to automake. | |||||
1999-11-17 | + Updated copyright information. | Jennifer Averett | 2 | -2/+4 | |
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 3 | -0/+189 | |
for RTEMS. |
