* | Rework. | Ralf Corsepius | 2005-11-11 | 1 | -22/+6 |
* | Cosmetics. | Ralf Corsepius | 2005-11-11 | 1 | -3/+0 |
* | Eliminate TEST. | Ralf Corsepius | 2005-11-11 | 1 | -5/+4 |
* | Expand tmitrontests.am. | Ralf Corsepius | 2005-11-11 | 1 | -2/+13 |
* | Eliminate DOCTYPES. | Ralf Corsepius | 2005-11-10 | 1 | -2/+1 |
* | AM_CPPFLAGS += -I..../support/include. | Ralf Corsepius | 2005-11-09 | 1 | -0/+2 |
* | Remove SRC, PRINT_SRC. | Ralf Corsepius | 2005-11-07 | 1 | -2/+0 |
* | Switch back to include compile.am instead of amcompile.am | Ralf Corsepius | 2005-11-07 | 1 | -1/+1 |
* | Partial conversion to automake. | Ralf Corsepius | 2005-11-07 | 1 | -9/+6 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 1 | -3/+3 |
* | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 2004-04-01 | 1 | -1/+1 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 1 | -1/+1 |
| | | | | * tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+2 |
| | | | | | * tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+1 |
| | | | | | * include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 3 | -3/+3 |
| | | | | | * include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tmitronsem01/Makefile.am: Reflect having moved automake. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -1/+1 |
| | | | | * tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -1/+1 |
| | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * tmitronsem01/init.c: Modified. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-19 | 1 | -1/+1 |
| | | | | * tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+1 |
| | | | | * tmitronsem01/Makefile.am: Include compile.am | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -6/+8 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Uncommitted remains of a previous patch from Ralf Corsepius | Joel Sherrill | 1999-11-30 | 1 | -0/+45 |
| | | | | <corsepiu@faw.uni-ulm.de> which converted fiels to automake. | ||||
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 2 | -2/+4 |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 3 | -0/+189 |
for RTEMS. |
