enable this support.
* tmitronsem01/init.c: Modified.
* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmitronsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* tmitronsem01/Makefile.am: Include compile.am
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
for RTEMS.
