* include/timesys.h: Convert to using c99 fixed size types.
* include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h,
tmitronsem01/tmitronsem01.doc: URL for license changed.
Addtional major bugs:
for RTEMS.
like signal dispatching.
