tmitronsem01/Makefile.am: Reflect having moved automake.
* tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tmitrontests.am: Remove DEFS.
Addtional major bugs:
for RTEMS.
