* | 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-04-03 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: Makefile.am: Eliminate _exe_/.exe. | ||||
* | 2008-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-17 | 1 | -0/+5 |
| | | | | | * include/timesys.h: Rename STACK_CHECKER_ON to more appropriate CONFIGURE_STACK_CHECKER_ENABLED. | ||||
* | 2008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-31 | 1 | -0/+5 |
| | | | | | * tmitronsem01/Makefile.am, tmitronsem01/init.c: Eliminate empty function from every benchmark timer driver. Fix spelling. | ||||
* | 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-02-01 | 1 | -0/+6 |
| | | | | | | * tmitronsem01/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+4 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-11 | 1 | -0/+5 |
| | | | | | * tmitronsem01/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead. | ||||
* | 2005-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-22 | 1 | -0/+5 |
| | | | | | * configure.ac: Remove RTEMS_ENABLE_BARE, BARE_CPU_CFLAGS, BARE_CPU_MODEL. | ||||
* | Fix my email address | Ralf Corsepius | 2005-11-13 | 1 | -5/+5 |
* | 2005-11-13 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-13 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: Convert to using *_PROGRAMS. | ||||
* | Fix typos. | Ralf Corsepius | 2005-11-11 | 1 | -1/+1 |
* | * tmitronsem01/Makefile.am: Rework. | Ralf Corsepius | 2005-11-11 | 1 | -0/+4 |
* | 2005-11-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-11 | 1 | -0/+5 |
| | | | | | * tmitrontests.am: Remove. * tmitronsem01/Makefile.am: Expand tmitrontests.am. | ||||
* | 2005-11-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-09 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: AM_CPPFLAGS += -I..../support/include. | ||||
| | | | | * tmitrontests.am: Set project_bspdir=$(PROJECT_ROOT) | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+4 |
| | | | | * tmitrontests.am: Remove LIB_VARIANT. | ||||
* | * tmitronsem01/Makefile.am: Remove SRC, PRINT_SRC. | Ralf Corsepius | 2005-11-07 | 1 | -0/+4 |
| | | | | * Makefile.am: Cleanup. | ||||
* | 2005-11-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-07 | 1 | -0/+6 |
| | | | | | | * tmitrontests.am: Add $(PGM): ${ARCH}/$(dirstamp). * tmitronsem01/Makefile.am: Partial conversion to automake. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | * tmitronsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. | Ralf Corsepius | 2004-04-01 | 1 | -0/+4 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 1 | -0/+4 |
| | | | | * tmitronsem01/system.h: Include <rtems/itron.h> instead of <itron.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 1 | -0/+4 |
| | | | | * include/timesys.h: Convert to using c99 fixed size types. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 1 | -0/+6 |
| | | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge-in include/Makefile.am. * configure.ac: Reflect changes above. | ||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 1 | -0/+4 |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+5 |
| | | | | | * tmitronsem01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-18 | 1 | -0/+4 |
| | | | | * tmitrontests.am: Add dirstamp support. | ||||
* | 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-17 | 1 | -0/+4 |
| | | | | * tmitrontests.am: Use $(mkdir_p) instead of $(mkinstalldirs). | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -0/+5 |
| | | | | | * include/Makefile.am: Reformat. * tmitronsem01/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-10 | 1 | -0/+4 |
| | | | | * configure.ac: Reflect having moved to testsuites/. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 1 | -0/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-02 | 1 | -0/+4 |
| | | | | * configure.ac:Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 1 | -0/+5 |
| | | | | | * include/timesys.h, tmitronsem01/init.c, tmitronsem01/system.h, tmitronsem01/tmitronsem01.doc: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-17 | 1 | -3/+3 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -0/+6 |
| | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. tmitronsem01/Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-05-27 | 1 | -0/+5 |
| | | | | | * configure.ac: Remove CC_CFLAGS_DEBUG_V. CC_CFLAGS_DEFAULT (obsolete). | ||||
| | | | | | * configure.ac: Remove CC_CFLAGS_PROFILE_V. Remove CC_LDFLAGS_PROFILE_V. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 1 | -0/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -0/+4 |
| | | | | * tmitronsem01/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -0/+11 |
| | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * tmitronsem01/init.c: Modified. | ||||
* | 2002-04-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-16 | 1 | -0/+4 |
| | | | | * configure.ac: Remove ENABLE_GCC28. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+9 |
| | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * tmitronsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-24 | 1 | -0/+4 |
| | | | | * tmitrontests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy. |
