path: root/testsuites/testdata (follow)
* testsuite: Add test states to the testsuit configuration files.Chris Johns2016-12-075-92/+92
| | | | | | | | | | | | | | | | Change the testsuite configuration files to hold state information about a test. The states are: exclude - Do not build the test expected-fail - The test is expected to fail indeterminate - The test may pass or may fail A message is printed just after the test's BEGIN message to indicate there is a special state for the test. No state message means the test is expected to pass. This support requires tests are correctly written to the use standard support to begin and end a test.
* testsuites/testdata/dltests-broken-on-this-bsp.tcfg: Add new dl tests 03-05Joel Sherrill2016-11-031-0/+3
* disable-intrcritical-tests.tcfg: New fileJoel Sherrill2015-04-011-0/+30
| | | | | | This file contains the list of interrupt critical section tests. There are some simulators these are unreliable on so they should just be ignored.
* testsuites/testdata: Add sets to disable all jffs2 and mrfs testsJoel Sherrill2015-03-222-0/+25
* dltests-broken-on-this-bsp.tcfg: New file used for dl* tests work aroundJoel Sherrill2015-03-061-0/+8
* rtems-test-check: Ignore tests which require real ISR based clock tickChris Johns2014-05-281-0/+72
BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details.
