* | rtems-test-check: Ignore tests which require real ISR based clock tick | Chris Johns | 2014-05-28 | 1 | -0/+72 |
BSPs for simulators which do not include a clock tick interrupt source are incapable of running some tests successfully. This is a common characteristic of some BSPs and a fixed set of tests. There is no point in duplicating this list of tests in those BSPs test configuration. Read testsuites/testdata/require-tick-isr.tcfg for details. |
