path: root/testsuites/testdata/disable-jffs2-tests.tcfg (follow)
* testsuite: Add fsjffs2gc01 to the disable JFFS tests.Chris Johns2017-05-241-0/+1
* testsuite: Add test states to the testsuit configuration files.Chris Johns2016-12-071-8/+8
| | | | | | | | | | | | | | | | Change the testsuite configuration files to hold state information about a test. The states are: exclude - Do not build the test expected-fail - The test is expected to fail indeterminate - The test may pass or may fail A message is printed just after the test's BEGIN message to indicate there is a special state for the test. No state message means the test is expected to pass. This support requires tests are correctly written to the use standard support to begin and end a test.
* testsuites/testdata: Add sets to disable all jffs2 and mrfs testsJoel Sherrill2015-03-221-0/+12
