Provide support functions to print the begin/end of test message.
Provide a test fatal extension to print out profiling reports in the
future.
Make it possible to use normal printf() if requested to allow output of
floating point numbers.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
In case the printf() blocks on a semaphore it was possible to end up in
a livelock.
* support/src/spin.c: Include "test_support.h".
Replaced Allocate_majority_of_workspace() with
rtems_workspace_allocate(). Replaced Allocate_majority_of_heap() with
rtems_heap_greedy_allocate().
* support/include/tmtests_empty_function.h: New.
* support/src/tmtests_empty_function.c,
support/src/tmtests_support.c:
Include "tmtests_empty_function.h".
Remove local decls (Missing prototypes).
* support/src/test_support.c: Avoid magic numbers.
* support/include/tmacros.h:
Remove fatal_posix_service_pointer_minus_one (unused).
* support/include/primode.h: New.
* Makefile.am: Add support/include/primode.h
* support/include/tmacros.h: Remove PRItime_t.
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* support/include/test_support.h: Fixed incorrect name in prototype.
* support/include/tmacros.h: Disable the check for dispatch disable
level for SMP tests. Another CPU may be inside RTEMS by the time
these checks are being done which would result in false failures.
* configure.ac, support/include/test_support.h:
* support/src/locked_print.c: New file.
PR 1777/cpukit
* support/include/tmacros.h, tmtests/tm26/task1.c,
tmtests/tm27/task1.c: Consolidated access to
_Thread_Dispatch_disable_level.
* support/src/tmtests_support.c:
loop_overhead and end_time are uint32_t's.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* support/src/tmtests_support.c: Fix warning.
* support/include/test_support.h, support/src/tmtests_empty_function.c:
Add helper so it is easier to write a basic repeated operation
tmtest.
* support/src/tmtests_support.c: New file.
* support/include/tmacros.h: Remove PRIdoff_t.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
* support/include/test_support.h, support/include/tmacros.h,
support/src/test_support.c: Added support functions to spin for a
number of ticks and to spin until the next tick.
* support/src/spin.c: New file.
* support/include/tmacros.h: Use rtems_test_assert() consistently
instead of system assert(). rtems_test_assert() is designed to
integrate into the RTEMS test suite infrastructure.
* support/include/tmacros.h: Add service to check status returned by
POSIX methods which return a pointer which is -1 on error. This
eliminated some casts.
* support/include/tmacros.h: Include rtems/score/thread.h.
Remove _Thread_Dispatch_disable_level.
Comment cleanups.
* support/include/tmacros.h: Add PRIxrtems_event_set.
(fatal_posix_service_status_errno) Add local "long" var "statx".
Add PRIdrtems_task_argument.
* support/include/tmacros.h: Add PRIdWatchdog_Interval.
Add PRIdrtems_interval.
* support/include/tmacros.h: Add PRIdPriority_Control.
Change PRIdrtems_task_priority to using PRIdPriority_Control.
* support/include/tmacros.h: Add PRItime_t.
* support/include/tmacros.h (print_time): Use PRIu32 instead of %d.
* support/include/test_support.h: Add missing prototypes.
* support/include/tmacros.h: Move _Thread_Dispatch_disable_level
outside of check_dispatch_disable_level.
* support/src/test_support.c: Add missing prototypes.
* support/include/tmacros.h: Include <inttypes.h>.
Move extern "C".
Let put_name use "int" instead "uint32_t" (Arg to putchar must be int).
* support/include/tmacros.h: Eliminate test routines TICKS_PER_SECOND
and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* support/src/test_support.c: Tinker with longest valid name.
