Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
but discovered independently.
* configure.in: Remove.
* include/tmacros.h: Attempt to print errno as further information.
* configure.in: Remove stubdr, wrapup, AC_INIT(include).
* Makefile.am: Remove stubdr, wrapup.
* stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c,
stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c,
stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/,
wrapup/: Remove.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
by the same application.
check is performed. This is needed in some timer service routines
since they are called from multiple disable levels.
check that the _Thread_Dispatch_disable_level is set to the
proper value (0 99% of the time). This automatic check significantly
reduces the chance of mismatching disable/enable dispatch pairs
while doing internal RTEMS work.
targopts.h file.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
