path: root/testsuites/support (follow)
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
| | | | * stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-272-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-132-0/+15
| | | | adds .cvsignore.
* Changed error checking macros for POSIX.Joel Sherrill2000-01-131-0/+60
* Now print strings -- not error numbers.Joel Sherrill2000-01-051-2/+3
* Added ifndef around build_time so pmacros.h and tmacros.h could be includedJoel Sherrill1999-11-221-0/+2
| | | | by the same application.
* Added code so if dispatching level is specified to be -1, then noJoel Sherrill1999-11-161-1/+1
| | | | | check is performed. This is needed in some timer service routines since they are called from multiple disable levels.
* Added code to the macros which checked directive status to alsoJoel Sherrill1999-11-161-20/+44
| | | | | | | check that the _Thread_Dispatch_disable_level is set to the proper value (0 99% of the time). This automatic check significantly reduces the chance of mismatching disable/enable dispatch pairs while doing internal RTEMS work.
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-051-1/+1
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* New configuration files added by patch fromJoel Sherrill1999-08-101-0/+11
| | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>".
* Made stopping for the pause an option which can be configured in theJoel Sherrill1997-01-291-0/+12
| | | | targopts.h file.
* added initial posix configuration supportJoel Sherrill1996-05-281-1/+2
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-2/+2
| | | | to avoid conflict with the standard POSIX routine pause(2).
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-6/+11
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-3/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-0/+7
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-2/+2
* cleanupJoel Sherrill1995-08-111-6/+8
* Initial revisionJoel Sherrill1995-05-111-0/+116
