* | JOEL, this file is dead. Don't re-add it. | Ralf Corsepius | 2005-11-11 | 1 | -4/+0 | |
* | 2005-11-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-11-10 | 1 | -0/+4 | |
| | | | | * support/.cvsignore: New file. | |||||
* | Remove (Merged into ..). | Ralf Corsepius | 2005-11-09 | 4 | -233/+0 | |
* | 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-22 | 2 | -1/+6 | |
| | | | | | * include/buffer_test_io.h: Use iprintf iff _NEWLIB_VERSION is defined. | |||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 | |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 | |
| | | | | * configure.ac: Require automake > 1.9. | |||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-20 | 2 | -9/+9 | |
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 2 | -3/+7 | |
| | | | | * include/tmacros.h: Convert to using c99 fixed size types. | |||||
* | 2004-03-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-03-25 | 2 | -1/+5 | |
| | | | | * configure.ac: Add 2nd arg to RTEMS_TOP. | |||||
* | Unused. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 | |
* | 2004-03-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-03-03 | 2 | -1/+5 | |
| | | | | * include/buffer_test_io.h: Correct typo. | |||||
* | 2004-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-02-04 | 2 | -0/+8 | |
| | | | | | * include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler mode. | |||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+7 | |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | |||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 | |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
* | 2003-12-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-12-16 | 2 | -0/+12 | |
| | | | | | | PR 544/tests * include/buffer_test_io.h: Various modifications to make tests account for resources and not print at inappropriate times. | |||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -12/+17 | |
| | | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. Use include_HEADERS. | |||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 | |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-10 | 2 | -1/+5 | |
| | | | | * configure.ac: Reflect having moved to testsuites/. | |||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -1/+5 | |
| | | | | * include/tmacros.h: URL for license changed. | |||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 | |
| | | | | * Makefile.am: Reflect having moved aclocal/. | |||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-17 | 1 | -1/+1 | |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -1/+5 | |
| | | | | Makefile.am: Reflect having moved automake. | |||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 | |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 | |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 | |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
| | | | | * configure.ac: AC_PREREQ(2.57). | |||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 | |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
* | 2002-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-21 | 3 | -14/+25 | |
| | | | | | | | * include/Makefile.am: Remove. * Makefile.am: Merge in former include/Makefile.am. * configure.ac: Reflect changes above. Take out unnecessary autoconf macros. | |||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 3 | -14/+151 | |
| | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/buffer_test_io.h: New file. | |||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+10 | |
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
* | 2001-11-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-11-07 | 1 | -2/+7 | |
| | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. * include/tmacros.h: Added fatal_directive_check_status_only(). | |||||
* | 2001-11-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-11-07 | 1 | -0/+6 | |
| | | | | | | | Tracked as PR72 but related to the object id problem (PR36) reported by Todor.Todorov@barco.com. but discovered independently. * include/tmacros.h: Added fatal_directive_check_status_only(). | |||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+35 | |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | |||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -0/+7 | |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||||
* | 2001-08-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-16 | 2 | -2/+8 | |
| | | | | * include/tmacros.h: Attempt to print errno as further information. | |||||
* | 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-05-10 | 1 | -0/+4 | |
| | | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]). | |||||
* | 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-26 | 2 | -1/+10 | |
| | | | | | | | | | * configure.in: Remove stubdr, wrapup, AC_INIT(include). * Makefile.am: Remove stubdr, wrapup. * stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c, stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c, stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/, wrapup/: Remove. | |||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 2 | -1/+5 | |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -0/+4 | |
| | | | | * stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am. | |||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 2 | -1/+5 | |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | |||||
* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 2 | -1/+6 | |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | |||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+4 | |
| | | | | * stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am | |||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-10 | 1 | -0/+3 | |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 2 | -0/+15 | |
| | | | | adds .cvsignore. | |||||
* | Changed error checking macros for POSIX. | Joel Sherrill | 2000-01-13 | 1 | -0/+60 | |
* | Now print strings -- not error numbers. | Joel Sherrill | 2000-01-05 | 1 | -2/+3 | |
* | Added ifndef around build_time so pmacros.h and tmacros.h could be included | Joel Sherrill | 1999-11-22 | 1 | -0/+2 | |
| | | | | by the same application. | |||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 1 | -2/+1 | |
* | Added code so if dispatching level is specified to be -1, then no | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
| | | | | | check is performed. This is needed in some timer service routines since they are called from multiple disable levels. | |||||
* | Added code to the macros which checked directive status to also | Joel Sherrill | 1999-11-16 | 1 | -20/+44 | |
| | | | | | | | check that the _Thread_Dispatch_disable_level is set to the proper value (0 99% of the time). This automatic check significantly reduces the chance of mismatching disable/enable dispatch pairs while doing internal RTEMS work. |
