path: root/testsuites/support (follow)
* added initial posix configuration supportJoel Sherrill1996-05-281-1/+2
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-2/+2
| | | | to avoid conflict with the standard POSIX routine pause(2).
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-6/+11
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-3/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-0/+7
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-2/+2
* cleanupJoel Sherrill1995-08-111-6/+8
* Initial revisionJoel Sherrill1995-05-111-0/+116
