* support/src/tmtests_empty_function.c: New file.
* support/include/test_support.h, support/src/test_support.c: New files.
* support/include/tmacros.h: Change TEST_INIT to CONFIGURE_INIT. Make
tmacros.h available to all POSIX tests. Add a clock_settime case for
< 1988.
* support/include/tmacros.h: Fix put_name to handle unprintable names.
* support/include/tmacros.h: Add new rtems_test_assert() which exits
rather than calling fatal error.
* support/include/tmacros.h: Add new helper for POSIX tests.
* support/include/buffer_test_io.h: Add support for using printk for
output in tests. This should be followed up by disabling the console
driver and other support when the tests are using printk.
PR 855/tests
* support/include/tmacros.h: Fix typo.
* support/.cvsignore: New file.
* include/buffer_test_io.h: Use iprintf iff _NEWLIB_VERSION is
defined.
* include/tmacros.h: Convert to using c99 fixed size types.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* include/buffer_test_io.h: Correct typo.
* include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler
mode.
PR 544/tests
* include/buffer_test_io.h: Various modifications to make tests account
for resources and not print at inappropriate times.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
Use include_HEADERS.
* configure.ac: Reflect having moved to testsuites/.
* include/tmacros.h: URL for license changed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Merge in former include/Makefile.am.
Take out unnecessary autoconf macros.
enable this support.
* include/buffer_test_io.h: New file.
Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
but discovered independently.
* configure.in: Remove.
* include/tmacros.h: Attempt to print errno as further information.
* configure.in: Remove stubdr, wrapup, AC_INIT(include).
* Makefile.am: Remove stubdr, wrapup.
* stubdr/Makefile.am, stubdr/open.c, stubdr/close.c, stubdr/init.c,
stubdr/stubdrv.h, stubdr/cntrl.c, stubdr/.cvsignore, stubdr/read.c,
stubdr/write.c, wrapup/Makefile.am, wrapup/.cvsignore, stubdr/,
wrapup/: Remove.
* stubdr/Makefile.am: Replace leaf.cfg w/ automake/lib.am.
* stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
