Replaced Allocate_majority_of_workspace() with
rtems_workspace_allocate(). Replaced Allocate_majority_of_heap() with
rtems_heap_greedy_allocate().
* support/src/test_support.c: Avoid magic numbers.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* support/include/test_support.h, support/include/tmacros.h,
support/src/test_support.c: Added support functions to spin for a
number of ticks and to spin until the next tick.
* support/src/spin.c: New file.
* support/src/test_support.c: Add missing prototypes.
* support/src/test_support.c: Tinker with longest valid name.
* support/include/test_support.h, support/src/test_support.c: New files.
