The <rtems/test-info.h> header file is required for every RTEMS test
program. Move the RTEMS test printer support to a dedicated header file
<rtems/test-printer.h>. This removes an unnecessary dependency to the
RTEMS printer support in <rtems/test-info.h>.
Tests using the RTEMS Testing Framework no longer depend on the
<rtems/printer.h>.
This file had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
Updates #3053.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros
had different implementations depending on the RTEMS_TEST_NO_PAUSE
define. This define was defined to 1 by default. The user was able to
change this via the undocumented --disable-test-no-pause configure
command line option.
Pausing tests and waiting for user input contradicts the goal of having
automated test runs. Remove this feature.
Update #3818.
Update #3818.
This bug surfaced due to sporadic failures in sptimecounter02. Adjust
rtems_test_spin_for_ticks() to include the partial tick in the argument
value.
Update #3409.
- Remove the macro defines and the need for tmacro.h by remapping the
symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
Add a tests enum and move all test banner test to the library in libmisc.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
This avoids an unnecessary use of the floating point unit.
Update #3076.
This completes the initial creation of rtems/inttypes.h based on all
existing PRIxxx definitions contained in RTEMS Project owned code.
closes #2983.
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
of this patch set.
closes #2443.
Replace _API_Mutex_Is_locked() with _API_Mutex_Is_owner().
The Allocator Mutex should not be locked outside a tested
service call. In an SMP test or heavily multithreaded test,
this is possible since another thread could have the lock
for an extended period of time but this is not the norm
for the tests.
updates 2319.
posix_memalign() is prototyped to take a non-NULL parameter. But our
test is deliberately passing one in. With the -Wnon-null warning flag
enabled, we will always get warnings on this test unless we disable
that warning for this single test case.
Add locked_vprintf(). Return an int just like printf(), etc.
Provide support functions to print the begin/end of test message.
Provide a test fatal extension to print out profiling reports in the
future.
Make it possible to use normal printf() if requested to allow output of
floating point numbers.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Delete _Thread_Dispatch_in_critical_section() and
_Thread_Is_dispatching_enabled().
Replaced Allocate_majority_of_workspace() with
rtems_workspace_allocate(). Replaced Allocate_majority_of_heap() with
rtems_heap_greedy_allocate().
* support/include/tmtests_empty_function.h: New.
* support/src/tmtests_empty_function.c,
support/src/tmtests_support.c:
Include "tmtests_empty_function.h".
Remove local decls (Missing prototypes).
* support/include/tmacros.h:
Remove fatal_posix_service_pointer_minus_one (unused).
* support/include/primode.h: New.
* Makefile.am: Add support/include/primode.h
* support/include/tmacros.h: Remove PRItime_t.
* support/include/pritime.h: New.
* Makefile.am: Add support/include/pritime.h
* support/include/test_support.h: Fixed incorrect name in prototype.
* support/include/tmacros.h: Disable the check for dispatch disable
level for SMP tests. Another CPU may be inside RTEMS by the time
these checks are being done which would result in false failures.
* configure.ac, support/include/test_support.h:
* support/src/locked_print.c: New file.
PR 1777/cpukit
* support/include/tmacros.h, tmtests/tm26/task1.c,
tmtests/tm27/task1.c: Consolidated access to
_Thread_Dispatch_disable_level.
* support/include/tmacros.h: Remove PRIxblksize_t, PRIxblkcnt_t.
* support/include/test_support.h, support/src/test_support.c: Add
Allocate_majority_of_heap().
* support/include/test_support.h, support/src/tmtests_empty_function.c:
Add helper so it is easier to write a basic repeated operation
tmtest.
* support/src/tmtests_support.c: New file.
* support/include/tmacros.h: Remove PRIdoff_t.
* support/include/tmacros.h: Changed check_dispatch_disable_level() to
treat all non-zero values of _Thread_Dispatch_disable_level equally.
