* include/tmacros.h: Convert to using c99 fixed size types.
* include/buffer_test_io.h: Correct typo.
* include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler
mode.
PR 544/tests
* include/buffer_test_io.h: Various modifications to make tests account
for resources and not print at inappropriate times.
* include/tmacros.h: URL for license changed.
enable this support.
* include/buffer_test_io.h: New file.
Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* include/tmacros.h: Added fatal_directive_check_status_only().
* include/tmacros.h: Attempt to print errno as further information.
by the same application.
check is performed. This is needed in some timer service routines
since they are called from multiple disable levels.
check that the _Thread_Dispatch_disable_level is set to the
proper value (0 99% of the time). This automatic check significantly
reduces the chance of mismatching disable/enable dispatch pairs
while doing internal RTEMS work.
targopts.h file.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
