by the same application.
check is performed. This is needed in some timer service routines
since they are called from multiple disable levels.
check that the _Thread_Dispatch_disable_level is set to the
proper value (0 99% of the time). This automatic check significantly
reduces the chance of mismatching disable/enable dispatch pairs
while doing internal RTEMS work.
targopts.h file.
to avoid conflict with the standard POSIX routine pause(2).
like signal dispatching.
