Provide support functions to print the begin/end of test message.
Provide a test fatal extension to print out profiling reports in the
future.
Make it possible to use normal printf() if requested to allow output of
floating point numbers.
* support/include/buffer_test_io.h: Use printk on AVR by default.
* support/include/buffer_test_io.h: Add support for using printk for
output in tests. This should be followed up by disabling the console
driver and other support when the tests are using printk.
* include/buffer_test_io.h: Use iprintf iff _NEWLIB_VERSION is
defined.
* include/buffer_test_io.h: Correct typo.
* include/buffer_test_io.h: Do not use iprintf() if in ANSI compiler
mode.
PR 544/tests
* include/buffer_test_io.h: Various modifications to make tests account
for resources and not print at inappropriate times.
enable this support.
* include/buffer_test_io.h: New file.
