path: root/testsuites/sptests (follow)
* Added support for rtems_message_queue_get_number_pending.Joel Sherrill1997-07-314-0/+21
* Used macro instead of hard coded number.Joel Sherrill1997-07-091-1/+1
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-22168-840/+840
* corrected printf specifications and added casts as necessary to eliminateJoel Sherrill1997-04-074-69/+76
| | | | warnings.
* added ifdef to avoid warning for unused variable.Joel Sherrill1997-04-071-2/+6
* corrected integer only definitions of "FP CHECK" routines to eliminateJoel Sherrill1997-04-071-3/+10
| | | | warnings.
* corrected printf format to avoid warningJoel Sherrill1997-04-023-7/+7
* _CPU_Trap_Table_area is now conditional based on whether or notJoel Sherrill1997-01-081-2/+5
| | | | the application requires rtems to allocate a trap table
* added castJoel Sherrill1996-09-181-1/+1
* extended Task_id and Task_name arrays to avoid indexing past end of array.Joel Sherrill1996-09-171-2/+2
* Added _Thread_Do_post_task_switch_extension variable.Joel Sherrill1996-06-131-0/+1
* added cpu_time_budget field to Thread_Control and removed the global variableJoel Sherrill1996-06-051-1/+0
| | | | _Thread_Ticks_remaining_in_timeslice.
* updated screenJoel Sherrill1996-06-035-40/+34
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-311-1/+1
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-2925-0/+50
| | | | or rtems initialization table in configuration table
* updates from Tony Bennett to correct calling sequences.Joel Sherrill1996-05-242-0/+2
* updates from Tony BennettJoel Sherrill1996-04-222-2/+4
* addition of optional user provided stack allocator means that we can notJoel Sherrill1996-04-221-14/+27
| | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured.
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-2210-36/+32
| | | | to avoid conflict with the standard POSIX routine pause(2).
* Dispersal of internal thread handler resulted in removal of someJoel Sherrill1996-02-211-16/+11
| | | | variables and renaming of others.
* removed post switch extensionJoel Sherrill1996-02-133-3/+0
* As part of implementing the new isr synchronization algorithm using aJoel Sherrill1996-02-091-1/+1
| | | | single enumerated set of states the set of event manager variables changed.
* Added RTEMS API control structure to per task memory usage macro.Joel Sherrill1996-01-191-1/+2
* Increased stack size.Joel Sherrill1996-01-192-2/+2
* increased stack spaceJoel Sherrill1996-01-172-2/+2
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-152-4/+4
* typos fixedJoel Sherrill1995-10-311-0/+5
* SPARC port passes all testsJoel Sherrill1995-10-3010-17/+48
* fixed missing CVS IDsJoel Sherrill1995-10-065-5/+5
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-278-24/+24
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* posix support initially addedJoel Sherrill1995-09-261-10/+10
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-221-3/+5
* Heap changes required some changes in this screen.Joel Sherrill1995-09-191-7/+17
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-1929-79/+77
* Added...Joel Sherrill1995-09-111-0/+45
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1158-1306/+1066
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-6/+26
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-2311-29/+28
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2341-41/+41
* Changed to reflect adding object class to idJoel Sherrill1995-08-182-2/+2
| | | | Added "0x" to printf of id
* Changed to reflect adding object class to idJoel Sherrill1995-08-187-24/+24
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-1742-182/+1355
* after testing go32 and cvme961Joel Sherrill1995-07-211-6/+6
* Ada95, gnat, go32Joel Sherrill1995-07-121-2/+2
* conditional added for the hppa gr27Joel Sherrill1995-06-051-0/+2
* Corrected minor number for "Null" device driverJoel Sherrill1995-05-311-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-245-13/+5
* Initial revisionJoel Sherrill1995-05-11192-0/+13983
