* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 1 | -1/+1 | |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | |||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 67 | -274/+314 | |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 30 | -0/+71 | |
| | | | | adds .cvsignore. | |||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 29 | -29/+0 | |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | |||||
* | Patch from Eric Norum <eric@cls.usask.ca> to implement this: | Joel Sherrill | 2000-01-21 | 1 | -14/+12 | |
| | | | | | | | | | | | | | | | | | | | | I'd like to propose a change to RTEMS task variables that I think would make them more useful. I think that it is early enough in their existence to still make changes to their API. 1) Change type from `int' to `void *'. 2) Add extra argument to task_variable_add -- if non-NULL, a pointer to a `destructor' function to be called when the task exits. This function would be called with that task's value of the task variable as its argument. In many cases, the `dtor' function could be `free'. rtems_status_code rtems_task_variable_add ( rtems_id tid, void **ptr, void (*dtor)(void *)); rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr); This would be all we'd need to cleanly and efficiently support C++ per-thread exception information without dragging in all that POSIX API stuff. | |||||
* | Added test case for broadcast to queue with messages pending. | Joel Sherrill | 2000-01-13 | 2 | -0/+14 | |
* | Added start and end herald. | Jennifer Averett | 2000-01-13 | 2 | -2/+6 | |
* | Fixed comment. | Joel Sherrill | 2000-01-06 | 1 | -2/+2 | |
* | Updated to reflect change in object class numbering due to ITRON API | Joel Sherrill | 2000-01-05 | 3 | -3/+3 | |
| | | | | addition. | |||||
* | Corrected test and screen to reflect implementation working. | Joel Sherrill | 2000-01-05 | 2 | -5/+13 | |
* | Changed screen to reflect change in object class numbers with ITRON | Joel Sherrill | 2000-01-05 | 4 | -19/+19 | |
| | | | | addition. | |||||
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 3 | -6/+1 | |
* | First attempt at adding simple binary semaphore in addition to the current | Joel Sherrill | 1999-12-13 | 5 | -1/+215 | |
| | | | | | "mutex" and counting semaphore. This is at the request of Eric Norum and his EPICS porting effort. | |||||
* | Missed in previous automake conversion patches from Ralf Corsepius | Joel Sherrill | 1999-11-23 | 1 | -0/+1 | |
| | | | | <corsepiu@faw.uni-ulm.de>. | |||||
* | Patch rtems-rc-19991117-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+23 | |
| | | | | to convert the libtests directory from Makefile.in to Makefile.am. | |||||
* | Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 28 | -28/+2 | |
| | | | | to fix some minor bugs in the conversion to automake. | |||||
* | Converted to automake. | Joel Sherrill | 1999-11-22 | 29 | -9/+1120 | |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 172 | -344/+172 | |
* | Added proper nesting level for dispatch disable check. | Joel Sherrill | 1999-11-16 | 3 | -3/+3 | |
* | Corrected nesting level on dispatching verification. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Corrected disable dispatch nesting count checks. | Joel Sherrill | 1999-11-16 | 1 | -7/+7 | |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 1 | -1/+4 | |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 1 | -0/+2 | |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 4 | -1/+98 | |
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 4 | -1/+104 | |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 4 | -15/+6 | |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
* | Increased stack space of task 2. | Joel Sherrill | 1999-11-01 | 2 | -2/+2 | |
* | Increased stack space for a task. | Joel Sherrill | 1999-11-01 | 2 | -1/+3 | |
* | Increased stack space for task 1. | Joel Sherrill | 1999-11-01 | 2 | -2/+2 | |
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 6 | -1/+250 | |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -4/+4 | |
| | | | | where wrapup left pieces out of the librtemsall.a. | |||||
* | Reran and replaced screen after report from Gerwin Pfab <pb@schenk.isar.de>. | Joel Sherrill | 1999-08-18 | 1 | -7/+9 | |
* | New configuration files added by patch from | Joel Sherrill | 1999-08-10 | 1 | -0/+21 | |
| | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>". | |||||
* | Added this file. | Joel Sherrill | 1999-02-10 | 1 | -0/+8 | |
* | Insure that the same output occurs when multiprocessing is disabled. | Joel Sherrill | 1998-12-03 | 5 | -1/+41 | |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -5/+17 | |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | |||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -3/+35 | |
| | | | | it work. | |||||
* | Fixed use of incorrect macro for minimum stack size. | Joel Sherrill | 1998-10-05 | 1 | -1/+1 | |
* | IDLE task stack size now specified as a field in the CPU Table for all | Joel Sherrill | 1998-09-23 | 1 | -1/+1 | |
| | | | | ports. | |||||
* | Under allcoated task stacks. | Joel Sherrill | 1998-08-03 | 1 | -1/+1 | |
* | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 1998-06-12 | 3 | -7/+37 | |
| | | | | The array is too long and needs to be shortened. | |||||
* | Fixed prototype of Fatal_Extension. | Joel Sherrill | 1998-05-04 | 2 | -18/+15 | |
| | | | | Fixed interface to cofndefs.h for initial extension set. | |||||
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 15 | -0/+30 | |
| | | | | more accurate. | |||||
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 | |
| | | | | for them. | |||||
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 4 | -4/+5 | |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -7/+7 | |
| | | | | the CPU family name constants. | |||||
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 1 | -2/+2 | |
* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 | |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 | |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 | |
