Since commit 6a6580331df3e09516d50f37d4dd5fd57825c08a, the local table is
zero-initialized. Use an initial object control block instead.
Update #4678.
The uniprocessor schedulers had some special case logic for the
PRIORITY_PSEUDO_ISR priority. Tasks with a priority of PRIORITY_PSEUDO_ISR
were allowed to preempt a not preemptible task. If other higher priority task
are made ready while a PRIORITY_PSEUDO_ISR task preempts a not preemptible
task, then the other tasks run before the not preemptible task. This made the
RTEMS_NO_PREEMPT mode ineffective.
Remove the PRIORITY_PSEUDO_ISR special case logic. This simplifies the
uniprocessor schedulers. Move the uniprocessor-specific scheduler support to
the new header file <rtems/score/scheduleruniimpl.h>.
Close #2365.
Update #4560.
The objects control blocks cannot be used to check the pre-initialization state
since they are allocated in a .noinit section.
Update #4678.
Update #4677.
Dirty or zero also the part of the .noinit section used by RTEMS.
Close #4678.
Place the statically allocated object control blocks, local tables, and thread
queue heads into the dedicated .noinit intput sections. The output section is
not zero initialized. Placing these elements into the .noinit section reduces
the system initialization time by decreasing the .bss section size.
It may improve the cache efficiency since the mostly read local tables are
placed in a contiguous memory area.
Update #4678.
Commit 80090639a62b50d7d66614ca789e4592924a06e5 altered the system state
change. Account for this in assert_allocator_protected_thread_context().
Update #2349.
Update #2349.
At some point during system initialization, the idle threads are created.
Afterwards, the boot processor basically executes within the context of an idle
thread with thread dispatching disabled. On some architectures, the
thread-local storage area of the associated thread must be set in dedicated
processor registers. Add the new CPU port function to do this:
void _CPU_Use_thread_local_storage( const Context_Control *context )
Close #4672.
Update #4667.
Updates #3053.
Updates #3053.
Manually adjusted location of SPDX annotation so #! remains first line.
Updates #3053.
Update #2349.
Update #2349.
Update #2349.
This file had no file header, copyright, or license. Based on git
history, added appropriate copyright and license.
This file had no header, copyright, or license. Based on git history,
These files had no file header, copyright, or license. Based on git
Theses files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #4625.
Updates #4625.
There were not a lot of these and they did not match the patterns
of the C.
Updates #4625.
Remove previous adjtime() implementation.
Update #2348.
Avoid a dependency on errno which might be a thread-local object. The tests
sp01, spstkalloc02, and sptls03 assume that no thread-local storage object is
present.
Update #4560.
GCC versions prior to 6.1 used a RTEMS thread model based on
rtems_gxx_*() functions. GCC version 6.1 or later uses the
self-contained synchronization objects of Newlib <sys/lock.h> for the
RTEMS thread model.
Remove the obsolete implementation.
Close #3143.
The test runner checks that there are no pending events after a test
case.
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something. Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY. This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
This allows to use additional members of the nodes for comparision.
Update #4534.
This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
Add a test to verify that intercepted exceptions can be resolved and
execution can be resumed.
