Close #3250.
Close #4081.
This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in
<rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and
_TOD_Days_since_last_leap_year[] static.
Update #4338.
Remove obsolete CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER application
configuration option which is unsupported since commit
69aa33490b1cd357519ab70b15ad150e11bb752e.
Users have access to the fatal error source and code though the fatal error
extension. The user-specific fatal error handling should be done in statically
initialized fatal error handlers. The _Internal_errors_What_happened was
updated after the fatal error extension. In addition, there was no API to get
the information stored in _Internal_errors_What_happened. In SMP
configurations, this object could contain a mix of different fatal errors.
Remove this object to save some bytes of storage.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
Prefer RTEMS_FATAL_SOURCE_EXCEPTION over
INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT since the fatal code
(rtems_exception_frame) provides more context.
This program contained an optional test case. It was enabled by the
RTEMS_COVERAGE define. The functions under test are not implemented by RTEMS.
Make the initialization of the per-CPU data optional.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Make sure that the linker sets work if placed in a library (this is how
they are used in RTEMS).
This adds a rtems_mutex_try_lock and a rtems_recursive_mutex_try_lock.
Update #4440.
Close #4410.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Close #3866.
affinity set of the task return RTEMS_INVALID_SIZE instead of
Close #4393.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
Close #4343.
Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task
storage alignment requirement.
Update #4267.
Update #4267.
Add a "Constraints" paragraph to the documentation.
Provide prototypes for programming language bindings. Use the macro
implementation to implement the corresponding functions.
Update #3993.
GCC 11 produced warnings like this:
items.c:21:1: warning: ignoring attribute
'section (".rtemsrwset.test_rw.content.0.1")' because it conflicts with
previous 'section (".rtemsrwset.test_rw.content.1")' [-Wattributes]
items.c:23:1: warning: ignoring attribute
'section (".rtemsroset.test_ro.content.0.OC")' because it conflicts with
previous 'section (".rtemsroset.test_ro.content.1")' [-Wattributes]
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
Replace runtime checks with compile time assertions. This makes the
INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
Update #4105.
Fix spmsgq_err01 on systems with 64-bit pointers and correct max value
mismatches and inaccuracies that are more noticable on 64-bit systems.
In contrast to message queues created by rtems_message_queue_create(), the
message queues constructed by this directive use a user-provided message buffer
storage area.
Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message
buffer storage areas.
Update #4007.
Merge CORE_message_queue_Buffer structure into
CORE_message_queue_Buffer_control.
Use a zero-length array for the actual message buffer. This reduces the
structure size on all targets.
Update #4007.
Return a status code and differentiate between error conditions.
Update #4007.
In contrast to rtems_task_create() this function constructs a task with
a user-provided task storage area. The new directive uses a
configuration structure instead of individual parameters.
Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a
task storage area based on the task attributes and the size dedicated to
the task stack and thread-local storage. This macro may allow future
extensions without breaking the API.
Add application configuration option
CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS
Workspace size estimate.
Update #3959.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
On some simulators, a clock tick interval of 1ms seems to be too short.
For example, the test failed on sparc/erc32 using the SIS.
Hide implementation details.
Update #3959.
Simplify object name to identifier directives. Using
_RTEMS_Name_to_id() to implement the directives enables a tail call
optimization.
Change license to BSD-2-Clause according to file history.
Update #3053.
Update #4032.
Update #4032.
This test support was replaced by T_interrupt_test() is no longer used.
