Use the BSD <sys/tree.h> implementation since it is faster, more
flexible and uses less storage. See https://github.com/sebhub/rb-bench.
This fixes a copy and paste error (from libbsd).
This function is hard to support in alternative implementations. It has
no internal use case.
This mutex implementation uses a thread priority queue with a simple
priority inheritance mechanism (similar to the object based mutexes).
The storage space must be supplied by the user (16 bytes on 32-bit
targets).
Move the storage for the thread queue heads to the threads. Each thread
provides a set of thread queue heads allocated from a dedicated memory
pool. In case a thread blocks on a queue, then it lends its heads to
the queue. In case the thread unblocks, then it takes a free set of
threads from the queue. Since a thread can block on at most one queue
this works. This mechanism is used in FreeBSD. The motivation for this
change is to reduce the memory demands of the synchronization objects.
On a 32-bit uni-processor configuration the Thread_queue_Control size is
now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced
the size as well).
Separate the thread queue heads and lock from the operations. This
enables the support for light weight objects which only support one
queuing discipline.
With this a _Freechain_Put( _Freechain_Get() ) works always.
Replace the extend function with an allocator since this fits better
to the current use case.
The problem is that empty structures have a different size in C and C++.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
This was obsolete and broken based upon recent time keeping changes.
Thie build option was previously enabled by adding
USE_TICKS_FOR_STATISTICS=1 to the configure command line.
This propagated into the code as preprocessor conditionals
using the __RTEMS_USE_TICKS_FOR_STATISTICS__ conditional.
Add an assert to ensure that the watchdog is the proper state for a
_Watchdog_Initialize(). This helps to detect invalid initializations
which may lead to a corrupt watchdog chain.
Update #2365.
Do a volatile clobber in the context switch extension to cover the path
through _Thread_Do_dispatch() invoked after interrupt processing.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
New test sptests/timecounter01.
Update #2271.
Update #2307.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
Replace the Thread_Priority_control with more general
Thread_queue_Operations which will be used for generic priority change,
timeout, signal and wait queue operations in the future.
Update #2273.
Add a thread wait timeout code. Replace _Event_Timeout() with a general
purpose _Thread_Timeout() watchdog handler.
Update #2273.
Merge THREAD_WAIT_STATE_SATISFIED, THREAD_WAIT_STATE_TIMEOUT,
THREAD_WAIT_STATE_INTERRUPT_SATISFIED, and
THREAD_WAIT_STATE_INTERRUPT_TIMEOUT into one state
THREAD_WAIT_STATE_READY_AGAIN. This helps to write generic routines to
block a thread.
Update #2273.
Use mostly the standard watchdog operations. Use a system event for
synchronization. This implementation is simpler and offers better SMP
performance.
Close #2131.
Rewrite the _Watchdog_Insert(), _Watchdog_Remove() and
_Watchdog_Tickle() functions to use iterator items to synchronize
concurrent operations. This makes it possible to get rid of the global
variables _Watchdog_Sync_level and _Watchdog_Sync_count which are a
blocking point for scalable SMP solutions.
Update #2307.
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations. Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
Remove thread queue parameter from _Thread_queue_Extract() since the
current thread queue is stored in the thread control block.
Avoid collision with <sys/param.h> defined PAGE_SIZE.
There may be a way to reduce the memory requirements but it
will require time to ensure the math is right and it passes
on all targets. At the current time, it fails on 22 BSPs which
run on simulators.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Remove _Thread_Acquire() and _Thread_Acquire_for_executing(). Add
utility functions for the default thread lock. Use the default thread
lock for the RTEMS events. There is no need to disable thread
dispatching and a Giant acquire in _Event_Timeout() since this was
already done by the caller.
Update #2273.
This helps on slow simulators.
Update the current time before the watchdog adjust so that timer
routines observe the new time.
