* PR145.
* sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present
in system (e.g. driver tasks). Also exit on minimum number of
switches not precise number.
* Fixed bug where resetting a timer that was not at the head
of one of the task timer chains resulted in the Timer Server
task waking up too far in the future.
* Added rtems_timer_get_information() directive to support testing.
* sp31/init.c, sp31/system.h, sp31/task1.c: Modified to test for
above condition.
* sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified
because priority added as argument to rtems_timer_initiate_server().
* Added tests for task-based timers. This included the new tests
sp30 and sp31.
* Makefile.am, configure.ac: Modified to reflect new tests and files.
* sp09/screen14.c, sp09/sp09.scn: Modified to add error checks
for task-based timer services.
* sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c,
sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c,
sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c,
sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h,
sp31/task1.c: New files.
* sp26/system.h: Properly account for stack memory used by
this test. Reported by Jerry Needell <jerry.needell@unh.edu>
and processed as PR78.
* configure.in: Remove.
* sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* sp20/system.h: Account for extra task stacks properly.
* sp13/sp13.scn: Id in screen had wrong class field value.
* sp13/system.h: Account for message buffer memory.
* sp13/task2.c: Remove unnecessary check for failure.
* sp298/sp28.scn: Minor adjustment so test output matches the screen
file.
* spsize/size.c: Use #if !defined(RTEMS_UNIX).
* sp21/Makefile.am: Remove libtest.
* sptests.am: Remove DEFS.
* sp20/sp20.scn: Corrected to reflect new addition.
* sp20/system.h: Removed comment reflecting history.
* sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c:
Added new task to test sequence of altering a period's length
while it is still active.
is no such thing on the C4x.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
significant things:
and PowerPC
same code base.
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
addition.
addition.
and his EPICS porting effort.
<corsepiu@faw.uni-ulm.de>.
