path: root/testsuites/sptests (follow)
* score: Fix task stack initializationSebastian Huber2021-03-271-1/+5
| | | | | | | | | Do not adjust the stack area begin address since this may confuse the stack allocator and result in failed stack frees. Account for the alignment overhead in the stack space size estimate. Check that the stack size is in the expected interval.
* rtems: Require RTEMS_PRIORITY for MrsP semaphoresSebastian Huber2021-03-161-9/+14
| | | | | | | | | MrsP semaphores are a generalization of the priority ceiling semaphores for SMP configurations. Priority ceiling semaphores are required to use the priority task wait queue discipline. Require this discipline also for MrsP semaphores. Close #4347.
* sp14: Fix for SMP or robust thread dispatchSebastian Huber2021-03-161-0/+5
| | | | Close #4343.
* CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZESebastian Huber2021-03-051-6/+6
| | | | | Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task storage alignment requirement.
* Add system initialization step for target hashSebastian Huber2021-02-261-0/+16
| | | | Update #4267.
* score: Add _IO_Base64url()Sebastian Huber2021-02-251-0/+12
| | | | Update #4267.
* rtems: Rework object services APISebastian Huber2021-02-031-8/+0
| | | | | | | | | Add a "Constraints" paragraph to the documentation. Provide prototypes for programming language bindings. Use the macro implementation to implement the corresponding functions. Update #3993.
* splinkersets01: Fix declarationSebastian Huber2021-01-231-2/+2
| | | | | | | | | | | | GCC 11 produced warnings like this: items.c:21:1: warning: ignoring attribute 'section (".rtemsrwset.test_rw.content.0.1")' because it conflicts with previous 'section (".rtemsrwset.test_rw.content.1")' [-Wattributes] items.c:23:1: warning: ignoring attribute 'section (".rtemsroset.test_ro.content.0.OC")' because it conflicts with previous 'section (".rtemsroset.test_ro.content.1")' [-Wattributes]
* rtems: Add <rtems/rtems/clockimpl.h>Sebastian Huber2020-12-021-0/+1
* config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZESebastian Huber2020-11-264-1/+72
| | | | | | | | | | In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181.
* Avoid INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULLSebastian Huber2020-11-265-61/+0
| | | | | | | Replace a runtime check with a compile time assertion. This makes the INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete. Update #4181.
* config: Simplify task stack allocator initSebastian Huber2020-11-197-75/+26
| | | | | Replace runtime checks with compile time assertions. This makes the INTERNAL_ERROR_BAD_STACK_HOOK obsolete.
* rtems: Add RTEMS_PARTITION_ALIGNMENTSebastian Huber2020-10-071-8/+9
| | | | Update #4105.
* spmsgq_err01: Use correct max values and fix 64bitKinsey Moore2020-10-051-3/+3
| | | | | Fix spmsgq_err01 on systems with 64-bit pointers and correct max value mismatches and inaccuracies that are more noticable on 64-bit systems.
* rtems: Add rtems_message_queue_construct()Sebastian Huber2020-09-282-9/+14
| | | | | | | | | | | In contrast to message queues created by rtems_message_queue_create(), the message queues constructed by this directive use a user-provided message buffer storage area. Add RTEMS_MESSAGE_QUEUE_BUFFER() to define a message buffer type for message buffer storage areas. Update #4007.
* score: Simplify CORE_message_queue_BufferSebastian Huber2020-09-281-2/+1
| | | | | | | | | | Merge CORE_message_queue_Buffer structure into CORE_message_queue_Buffer_control. Use a zero-length array for the actual message buffer. This reduces the structure size on all targets. Update #4007.
* score: Improve _CORE_message_queue_Initialize()Sebastian Huber2020-09-282-6/+7
| | | | | | Return a status code and differentiate between error conditions. Update #4007.
* rtems: Add rtems_task_construct()Sebastian Huber2020-09-173-10/+18
| | | | | | | | | | | | | | | | | In contrast to rtems_task_create() this function constructs a task with a user-provided task storage area. The new directive uses a configuration structure instead of individual parameters. Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a task storage area based on the task attributes and the size dedicated to the task stack and thread-local storage. This macro may allow future extensions without breaking the API. Add application configuration option CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS Workspace size estimate. Update #3959.
* CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZESebastian Huber2020-09-174-2/+84
| | | | | | | | | | | Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074.
* spintrcritical08: Increase clock tick intervalSebastian Huber2020-09-101-1/+1
| | | | | On some simulators, a clock tick interval of 1ms seems to be too short. For example, the test failed on sparc/erc32 using the SIS.
* score: Add <rtems/score/freechainimpl.h>Sebastian Huber2020-08-311-1/+1
| | | | | | Hide implementation details. Update #3959.
* rtems: Add _RTEMS_Name_to_id()Sebastian Huber2020-08-311-2/+2
| | | | | | | | | | Simplify object name to identifier directives. Using _RTEMS_Name_to_id() to implement the directives enables a tail call optimization. Change license to BSD-2-Clause according to file history. Update #3053.
* spintrcritical22: Use right thread wait flagsSebastian Huber2020-08-211-1/+1
* spintrcritical16: Use right thread wait flagsSebastian Huber2020-08-211-1/+1
* spintrcritical23: Fix unused variable warningsSebastian Huber2020-08-201-2/+2
* sp37: Fix unused variable warningsSebastian Huber2020-08-201-0/+2
* spintrcritical23: Restore runner prioritySebastian Huber2020-08-111-0/+8
* spmisc01: Include missing header fileSebastian Huber2020-07-241-0/+2
| | | | Update #4032.
* score: Add RTEMS_WEAKSebastian Huber2020-07-244-1/+108
| | | | Update #4032.
* spintrcritical_support: RemoveSebastian Huber2020-07-232-224/+0
| | | | This test support was replaced by T_interrupt_test() is no longer used.
* spintrcritical24: Use T_interrupt_test()Sebastian Huber2020-07-233-39/+119
* spintrcritical23: Use T_interrupt_test()Sebastian Huber2020-07-233-44/+88
* spintrcritical22: Use T_interrupt_test()Sebastian Huber2020-07-233-40/+87
* spintrcritical21: Use T_interrupt_test()Sebastian Huber2020-07-234-140/+149
* spintrcritical20: Use T_interrupt_test()Sebastian Huber2020-07-233-59/+115
* spintrcritical18: Use T_interrupt_test()Sebastian Huber2020-07-233-49/+128
* spintrcritical16: Use T_interrupt_test()Sebastian Huber2020-07-233-60/+115
* spintrcritical15: Use T_interrupt_test()Sebastian Huber2020-07-233-54/+117
* spintrcritical13/14: Use T_interrupt_test()Sebastian Huber2020-07-234-67/+147
* spintrcritical11/12: Use T_interrupt_test()Sebastian Huber2020-07-234-51/+126
* spintrcritical10: Use T_interrupt_test()Sebastian Huber2020-07-233-126/+109
* spintrcritical09: Use T_interrupt_test()Sebastian Huber2020-07-233-50/+103
* spintrcritical08: Use T_interrupt_test()Sebastian Huber2020-07-233-83/+157
* spintrcritical06/spintrcritical07: Remove testsSebastian Huber2020-07-239-242/+0
| | | | | | These two tests check conditions which no longer exist in the thread queue implementation. The are obsolete since the change to use red-black trees for the priority queues.
* spintrcritical01/2/3/4/5: Use T_interrupt_test()Sebastian Huber2020-07-237-96/+191
* libtest: Add T_get_one_clock_tick_busy()Sebastian Huber2020-07-231-1/+1
| | | | Update #3199.
* libtest: Add T_busy()Sebastian Huber2020-07-231-1/+2
| | | | Update #3199.
* libtest: <rtems/test.h> to <rtems/test-info.h>Sebastian Huber2020-07-234-4/+4
| | | | | | | | Rename this header file to later move <t.h> to <rtems/test.h>. The main feature provided by <rtems/test-info.h> is the output of standard test information which is consumed by the RTEMS Tester. Update #3199.
* rtems: Remove deprecated rtems_io_lookup_name()Sebastian Huber2020-07-141-21/+0
| | | | Close #3420.
* rtems: Remove RTEMS_MP_NOT_CONFIGURED errorSebastian Huber2020-06-1812-94/+4
| | | | | | | | | | | | | | Some objects can be created with a local or global scope in a multiprocessing network. In non-multiprocessing configurations setting the scope to local or global had no effect since such a system can be viewed as a multiprocessing network with just one node. One and all nodes is the same in such a network. However, if multiprocessing was configured, creation of a global object in a single node network resulted in an RTEMS_MP_NOT_CONFIGURED error. Remove this error condition for symmetry to the non-multiprocessing setup. This is in line with the task affinity behaviour in SMP systems. Update #4005.
