* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 4 | -4/+5 | |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -7/+7 | |
| | | | | the CPU family name constants. | |||||
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 1 | -2/+2 | |
* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 | |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 | |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 | |
* | Increased stack space of tasks. | Joel Sherrill | 1998-02-19 | 1 | -1/+1 | |
* | Increased stack size of initialization task. | Joel Sherrill | 1998-02-19 | 1 | -0/+1 | |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 167 | -167/+167 | |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 | |
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 | |
| | | | | for the returned old_isr_handler was non-NULL. | |||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 168 | -336/+336 | |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 | |
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 168 | -840/+840 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 4 | -69/+76 | |
| | | | | warnings. | |||||
* | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1997-04-07 | 1 | -2/+6 | |
* | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1997-04-07 | 1 | -3/+10 | |
| | | | | warnings. | |||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 3 | -7/+7 | |
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 1 | -2/+5 | |
| | | | | the application requires rtems to allocate a trap table | |||||
* | added cast | Joel Sherrill | 1996-09-18 | 1 | -1/+1 | |
* | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1996-09-17 | 1 | -2/+2 | |
* | Added _Thread_Do_post_task_switch_extension variable. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 | |
* | added cpu_time_budget field to Thread_Control and removed the global variable | Joel Sherrill | 1996-06-05 | 1 | -1/+0 | |
| | | | | _Thread_Ticks_remaining_in_timeslice. | |||||
* | updated screen | Joel Sherrill | 1996-06-03 | 5 | -40/+34 | |
* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 1 | -1/+1 | |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | |||||
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 25 | -0/+50 | |
| | | | | or rtems initialization table in configuration table | |||||
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 2 | -0/+2 | |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 2 | -2/+4 | |
* | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1996-04-22 | 1 | -14/+27 | |
| | | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured. | |||||
* | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 1996-02-22 | 10 | -36/+32 | |
| | | | | to avoid conflict with the standard POSIX routine pause(2). | |||||
* | Dispersal of internal thread handler resulted in removal of some | Joel Sherrill | 1996-02-21 | 1 | -16/+11 | |
| | | | | variables and renaming of others. | |||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 3 | -3/+0 | |
* | As part of implementing the new isr synchronization algorithm using a | Joel Sherrill | 1996-02-09 | 1 | -1/+1 | |
| | | | | single enumerated set of states the set of event manager variables changed. | |||||
* | Added RTEMS API control structure to per task memory usage macro. | Joel Sherrill | 1996-01-19 | 1 | -1/+2 | |
* | Increased stack size. | Joel Sherrill | 1996-01-19 | 2 | -2/+2 | |
* | increased stack space | Joel Sherrill | 1996-01-17 | 2 | -2/+2 | |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 2 | -4/+4 | |
* | typos fixed | Joel Sherrill | 1995-10-31 | 1 | -0/+5 | |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 10 | -17/+48 | |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 5 | -5/+5 | |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 8 | -24/+24 | |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -10/+10 | |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 1 | -3/+5 | |
* | Heap changes required some changes in this screen. | Joel Sherrill | 1995-09-19 | 1 | -7/+17 | |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 29 | -79/+77 | |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | |||||
* | Added... | Joel Sherrill | 1995-09-11 | 1 | -0/+45 | |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 58 | -1306/+1066 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
* | Added unused priority ceiling parameter to rtems_semaphore_create. | Joel Sherrill | 1995-08-28 | 2 | -6/+26 | |
| | | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core. | |||||
* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 11 | -29/+28 | |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. |
