path: root/testsuites/sptests (follow)
* Add config.h.inRalf Corsepius2011-03-011-0/+1
* 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-222-0/+5
| | | | * configure.ac: Add AC_CONFIG_HEADER(config.h).
* 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-221-0/+52
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/buffered_io.c, sp07/init.c, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp10/init.c, sp11/init.c, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/task1.c, sp16/init.c, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/task1.c, sp17/task2.c, sp18/init.c, sp19/first.c, sp19/fptask.c, sp19/init.c, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/task1.c, sp21/init.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/task1.c, sp23/init.c, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/task1.c, sp25/init.c, sp25/task1.c, sp26/init.c, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp30/init.c, sp30/resume.c, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp36/strict_order_mut.c, sp37/init.c, sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, sp49/init.c, sp50/init.c, sp51/init.c, sp52/init.c, sp54/init.c, sp55/init.c, sp56/init.c, sp57/init.c, sp58/init.c, sp59/init.c, sp60/init.c, sp62/init.c, sp63/init.c, sp64/init.c, sp65/init.c, sp66/init.c, sp67/init.c, sp68/init.c, sp69/init.c, sp70/init.c, sp71/init.c, sp72/init.c, spassoc01/init.c, spchain/init.c, spclockget/init.c, spcoverage/init.c, sperror01/init.c, sperror02/init.c, sperror03/init.c, spfatal_support/consume_sems.c, spfatal_support/init.c, spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c, spfifo05/init.c, spheapprot/init.c, spintrcritical01/init.c, spintrcritical06/init.c, spintrcritical08/init.c, spintrcritical09/init.c, spintrcritical10/init.c, spintrcritical11/init.c, spintrcritical13/init.c, spintrcritical15/init.c, spintrcritical16/init.c, spintrcritical17/init.c, spintrcritical_support/intrcritical.c, spmkdir/init.c, spmountmgr01/init.c, spnotepad01/init.c, spobjgetnext/init.c, spprintk/init.c, spprivenv01/init.c, spsize/getint.c, spsize/init.c, spsize/size.c, spstkalloc/init.c, spthreadq01/init.c, spwatchdog/delay.c, spwatchdog/init.c, spwatchdog/prtime.c, spwatchdog/task1.c, spwkspace/init.c: Add HAVE_CONFIG_H.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-22205-3/+820
* 2011-02-14 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-02-142-2/+5
| | | | * sp09/Makefile.am: Switch to all managers since this is all of them.
* 2011-02-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-082-2/+5
| | | | | * sp69/init.c: Use "ld" instead of PRId32 to print struct timespec->tv_nsec.
* 2011-02-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-082-1/+5
| | | | * sp19/inttest.h: Use PRIx32 instead of "lx".
* 2011-02-02 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-02-022-6/+9
| | | | * sp04/tswitch.c: Shrink memory requirements.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-022-2/+6
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2010-11-26 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-11-262-0/+8
| | | | * spchain/init.c: Added test case.
* 2010-11-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-11-253-0/+26
| | | | * spchain/init.c, spchain/spchain.scn: More test cases.
* 2010-11-24 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-11-242-20/+47
| | | | | | PR 1647/cpukit * spsize/size.c: Update documentation to reflect refactoring of SuperCore to add Scheduler Handler.
* 2010-11-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-11-163-2/+27
| | | | | * sp70/init.c, sp70/sp70.scn: Fix bug in test which lead to random memory corruption.
* 2010-10-25 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-262-1/+18
| | | | * spchain/init.c: Attempt to improve coverage.
* 2010-10-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-10-253-3/+7
| | | | * spchain/init.c, spwatchdog/task1.c: Do not violate chain API.
* 2010-10-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-10-042-41/+22
| | | | * spfifo03/spfifo03.scn: Replace file.
* 2010-10-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-10-032-1/+5
| | | | * spsize/size.c: Fix typo.
* 2010-08-26 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-263-2/+40
| | | | | | PR 1663/testing * spmkdir/init.c, spmkdir/spmkdir.scn: Added some test outputs to the test.
* 2010-08-25 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-258-1/+211
| | | | | | * spheapprot/.cvsignore, spheapprot/Makefile.am, spheapprot/spheapprot.doc, spheapprot/spheapprot.scn: New files. * Makefile.am, configure.ac: Reflect changes above.
* 2010-08-24 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-244-1/+114
| | | | | * spchain/init.c, spchain/spchain.doc, spchain/spchain.scn: New test cases.
* Removed.Sebastian Huber2010-08-231-587/+0
* 2010-08-23 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-2314-1/+765
| | | | | | | | | * spfatal24/.cvsignore, spfatal24/Makefile.am, spfatal24/spfatal24.doc, spfatal24/spfatal24.scn, spfatal24/testcase.h, spfatal25/.cvsignore, spfatal25/Makefile.am, spfatal25/spfatal25.doc, spfatal25/spfatal25.scn, spfatal25/testcase.h: New files. * Makefile.am, configure.ac: Reflect changes above.
* 2010-08-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-1011-85/+68
| | | | | | | | | | PR 1658/cpukit * Makefile.am, configure.ac: If the system is not up, consider it a fatal error. This eliminated sp61 and added spfatal23. * spfatal23/.cvsignore, spfatal23/Makefile.am, spfatal23/spfatal23.doc, spfatal23/spfatal23.scn, spfatal23/testcase.h: New files. * sp61/.cvsignore, sp61/Makefile.am, sp61/init.c, sp61/sp61.doc, sp61/sp61.scn: Removed.
* 2010-08-10 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-08-102-0/+12
| | | | | | PR 1663/testing * spmkdir/init.c: New cases to get the error path in rtems_mkdir routine.
* 2010-08-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-094-19/+14
| | | | | | PR 1661/testing * spfifo02/init.c, spmountmgr01/init.c, spprivenv01/init.c: Eliminate most references to RTEMS_Malloc_Heap.
* 2010-08-09 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-093-29/+8
| | | | | * sp09/screen12.c: Update for rtems_region_create() changes. * sp09/sp09.scn: Update.
* 2010-08-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-08-082-2/+5
| | | | | PR 1647/testing * spsize/size.c: Remove redundant initialize uninitialized to 0.
* 2010-07-30 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-07-302-1/+7
| | | | | | PR 1599/cpukit * spsize/size.c: Rename _Context_Switch_necessary to _Thread_Dispatch_necessary to more properly reflect the intent.
* 2010-07-29 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-298-1/+209
| | | | | | | PR 1621/testing * Makefile.am, configure.ac: Improve coverage of private environment. * spprivenv01/.cvsignore, spprivenv01/Makefile.am, spprivenv01/init.c, spprivenv01/spprivenv01.doc, spprivenv01/spprivenv01.scn: New files.
* 2010-07-27 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-273-0/+24
| | | | | * sp43/init.c, sp43/sp43.scn: Add code to exercise case where an API pointer is NULL when getting an object name.
* 2010-07-27 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-273-2/+29
| | | | | * sp11/sp11.scn, sp11/task1.c: Add test case for receiving all events no wait but the condition is only partially satisfied.
* 2010-07-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-268-1/+154
| | | | | | | * Makefile.am, configure.ac: Add test to extract a task blocked with timeout on a priority ordered thread queue. * sp72/.cvsignore, sp72/Makefile.am, sp72/init.c, sp72/sp72.doc, sp72/sp72.scn: New files.
* 2010-07-16 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-164-2/+37
| | | | | | | PR 1617/testing * spmountmgr01/init.c, spmountmgr01/spmountmgr01.scn, spmountmgr01/spmountmgr01.doc: Added cases to exercise mount-mktgt.c.
* 2010-07-15 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-158-1/+183
| | | | | | | | | PR 1617/testing * spmountmgr01/init.c, spmountmgr01/Makefile.am, spmountmgr/.cvsignore, spmountmgr01/spmountmgr01.doc, spmountmgr01/spmountmgr01.scn: New test which improves coverage of mount-mgr.c under libcsupport. * Makefile.am, configure.ac: Changes to accommodate the new test.
* 2010-07-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-144-10/+61
| | | | | * spprintk/init.c, spprintk/spprintk.doc, spprintk/spprintk.scn: Clean up and add test of getchark().
* 2010-07-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-142-2/+6
| | | | * spfatal21/Makefile.am: Fix typo.
* 2010-07-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-1413-2/+180
| | | | | | | | | * Makefile.am, configure.ac: Add tests for sbrk fatal error case and libio initialization fatal error case. * spfatal21/.cvsignore, spfatal21/Makefile.am, spfatal21/spfatal21.doc, spfatal21/spfatal21.scn, spfatal21/testcase.h, spfatal22/.cvsignore, spfatal22/Makefile.am, spfatal22/spfatal22.doc, spfatal22/spfatal22.scn, spfatal22/testcase.h: New files.
* 2010-07-14 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-149-33/+30
| | | | | | | | | | | | * spintrcritical06/init.c: Switch semaphore obtain timeouts of variants. Cleanup. * spintrcritical05/spintrcritical05.scn, spintrcritical06/spintrcritical06.scn, spintrcritical07/spintrcritical07.scn, spintrcritical11/spintrcritical11.scn, spintrcritical12/spintrcritical12.scn, spintrcritical13/spintrcritical13.scn, spintrcritical14/spintrcritical14.scn: Update.
* 2010-07-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-088-1/+92
| | | | | | | * Makefile.am, configure.ac: Readd spfatal09 as a malloc initialization fatal error. * spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc, spfatal09/spfatal09.scn, spfatal09/testcase.h: New files.
* 2010-07-07 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-078-2/+344
| | | | | | | | PR 1603/testing * spassoc01/init.c, spassoc01/Makefile.am, spassoc01/spassoc01.doc, spassoc01/spassoc01.scn: Added new test. * Makefile.am, configure.ac: Added new test spassoc01 for rtems_assoc routines.
* 2010-07-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-072-15/+8
| | | | | | PR 1606/cpukit * spfatal_support/init.c: Remove INTERNAL_ERROR_INVALID_WORKSPACE_ADDRESS since it is not generated.
* 2010-07-08 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-07-0730-121/+59
| | | | | | | | | | | | | | | | | | | | | * spfatal09/.cvsignore, spfatal09/Makefile.am, spfatal09/spfatal09.doc, spfatal09/spfatal09.scn, spfatal09/testcase.h: Removed files. * Makefile.am, configure.ac: Reflect changes above. * spfatal_support/init.c: Print end of test message in case of success. Stop multitasking in the fatal error extension. * spfatal03/testcase.h, spfatal07/testcase.h: Use printk() instead of puts(). * spfatal01/spfatal01.scn, spfatal02/spfatal02.scn, spfatal03/spfatal03.scn, spfatal04/spfatal04.scn, spfatal05/spfatal05.scn, spfatal06/spfatal06.scn, spfatal07/spfatal07.scn, spfatal08/spfatal08.scn, spfatal10/spfatal10.scn, spfatal11/spfatal11.scn, spfatal12/spfatal12.scn, spfatal13/spfatal13.scn, spfatal14/spfatal14.scn, spfatal15/spfatal15.scn, spfatal16/spfatal16.scn, spfatal17/spfatal17.scn, spfatal18/spfatal18.scn, spfatal19/spfatal19.scn, spfatal20/spfatal20.scn: Update.
* 2010-07-06 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-063-4/+14
| | | | | * sp21/init.c, sp21/sp21.scn: Tidy up with one last case to get 100% coverage of rtems_io_lookup_name().
* 2010-07-06 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-07-066-301/+237
| | | | | | * sp21/Makefile.am, sp21/init.c, sp21/sp21.scn: Add rtems_io_lookup_name() and simplify test. * sp21/system.h, sp21/task1.c: Removed.
* 2010-07-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-068-1/+93
| | | | | | | * Makefile.am, configure.ac: Add new fatal error test for termios initialize. * spfatal20/.cvsignore, spfatal20/Makefile.am, spfatal20/spfatal20.doc, spfatal20/spfatal20.scn, spfatal20/testcase.h: New files.
* 2010-07-05 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-058-1/+369
| | | | | | | PR 1600/testing * spfifo05/init.c, spfifo05/spfifo05.doc, spfifo05/spfifo05.scn, spfifo05/Makefile.am: New tests for pipe/fifo routines. * Makefile.am, configure.ac: Add new test.
* 2010-07-02 Bharath Suri <bharath.s.jois@gmail.com>Joel Sherrill2010-07-028-1/+182
| | | | | | | | PR 1600/testing * spfifo04/init.c, spfifo04/spfifo04.doc, spfifo04/spfifo04.scn, spfifo04/Makefile.am: New files to improve coverage on fifo/pipe routines * Makefile.am, configure.ac: Add new test.
* 2010-07-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-012-49/+53
| | | | * sp68/init.c: Add alignment to region_area. Fix spelling.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-292-3/+9
| | | | | | | PR 1573/cpukit * spsize/size.c: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-282-1/+5
| | | | * sp69/Makefile.am: Really needs spin.c
