* | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-30 | 1 | -0/+2 |
| | | | | | * sp14/asr.c: Remove PRIxrtems_signal_set (moved to tmacros.h). Include "tmacros.h". | ||||
* | Remove PRIxrtems_signal_set (moved to tmacros.h). | Ralf Corsepius | 2009-10-30 | 1 | -3/+1 |
| | | | | | * sp63/init.c: Pass UINTPTR_MAX instead of 0xffffffff to _Heap_Allocate for 16bit compliance. | ||||
* | Pass UINTPTR_MAX instead of 0xffffffff to _Heap_Allocate for 16bit compliance. | Ralf Corsepius | 2009-10-30 | 1 | -1/+1 |
* | 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-30 | 1 | -0/+4 |
| | | | | * sp44/init.c: Another printf format fix. | ||||
* | Another printf format fix. | Ralf Corsepius | 2009-10-30 | 1 | -1/+1 |
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 2 | -0/+7 |
| | | | | | | * sp37/init.c: Add local prototypes for rtems_interrupt_disable, rtems_interrupt_enable, rtems_interrupt_flash, rtems_interrupt_is_in_progress. | ||||
* | 2009-10-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 2 | -8/+29 |
| | | | | | | | | | | * sp43/init.c: Add local prototypes for rtems_object_api_minimum_class, rtems_object_api_maximum_class, rtems_build_id, rtems_build_name, rtems_object_id_api_maximum, rtems_object_id_api_minimum, rtems_object_id_get_api, rtems_object_id_get_class, rtems_object_id_get_index, rtems_object_id_get_node. Spray PRId32's into printf's for 16bit target complianance. | ||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-29 | 1 | -0/+5 |
| | | | | | * sp37/init.c: Add local prototype for rtems_interrupt_level_attribute. | ||||
* | Add local prototype for rtems_interrupt_level_attribute. | Ralf Corsepius | 2009-10-29 | 1 | -0/+3 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+2 |
| | | | | | * sp29/init.c: Include "tmacros.h". Misc. changes related to rtems_intervals. | ||||
* | Include "tmacros.h". | Ralf Corsepius | 2009-10-27 | 1 | -4/+6 |
| | | | | | * sp14/asr.c: Add PRIxrtems_signal_set. Use PRIxrtems_signal_set to print rtems_signal_set's. | ||||
* | Add PRIxrtems_signal_set. | Ralf Corsepius | 2009-10-27 | 1 | -2/+5 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+1 |
| | | | | * sp13/task3.c: Use PRIu32 to print "count". | ||||
* | Use PRIu32 to print "count". | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -1/+3 |
| | | | | | * sp09/screen12.c: Segment sizes are uintptr_t's. * sp09/screen11.c: Use size_t for "size". | ||||
* | Segment sizes are uintptr_t's. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Use size_t for "size". | Ralf Corsepius | 2009-10-27 | 1 | -2/+2 |
| | | | | * sp62/init.c: segment sizes are uintptr_t's. | ||||
* | segment sizes are uintptr_t's. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
| | | | | | * sp25/task1.c: Use PRIuPTR to print segment_size's. * sp21/task1.c: Add PRIurtems_device_major_number. | ||||
* | Use PRIuPTR to print segment_size's. | Ralf Corsepius | 2009-10-27 | 1 | -2/+2 |
* | Add PRIurtems_device_major_number. | Ralf Corsepius | 2009-10-27 | 1 | -1/+4 |
| | | | | | * sp11/task1.c, sp11/task2.c: Use PRIxrtems_event_set to print rtems_event_set's. | ||||
* | Use PRIxrtems_event_set to print rtems_event_set's. | Ralf Corsepius | 2009-10-27 | 2 | -14/+14 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 2 | -2/+5 |
| | | | | | | * sp09/screen13.c: Revert previous change. Remove broken extraneous line seemingly having crept into in 2009-08-10 patch. | ||||
* | Remove extraneous argument to print. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
| | | | | * spsize/size.c: Use PRIu32 to print sys_req. | ||||
* | Use PRIu32 to print sys_req. | Ralf Corsepius | 2009-10-27 | 1 | -2/+3 |
| | | | | * sp37/init.c: Add missing argument to printf. | ||||
* | Add missing argument to printf. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2009-10-27 | 6 | -15/+15 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 |
| | | | | | | * sp44/init.c, sp35/priinv.c, sp33/init.c, sp28/init.c, sp12/pritask.c, sp34/changepri.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | ||||
| | | | | | * sp25/task1.c: segment_size is uintptr_t. * spfatal06/testcase.h: Add missing return. | ||||
* | segment_size is uintptr_t. | Ralf Corsepius | 2009-10-27 | 1 | -3/+3 |
* | Add missing return. | Ralf Corsepius | 2009-10-27 | 1 | -0/+1 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+3 |
| | | | | | | * sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c: Duplicate code from rtems_name_to_characters to convert rtems_name's into char arrays. | ||||
* | Duplicate code from rtems_name_to_characters to convert rtems_name's into ↵ | Ralf Corsepius | 2009-10-27 | 4 | -20/+44 |
| | | | | char arrays. | ||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+7 |
| | | | | | | | * sp09/screen13.c: Comment out unused return status. * sp63/init.c: Use PRIu32 to print uint32_t's. * sp33/init.c: Use PRIu32 to print uint32_t's. * sp28/init.c: Use PRIu32 to print uint32_t's. | ||||
* | Comment out unused return status. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Use PRIu32 to print uint32_t's. | Ralf Corsepius | 2009-10-27 | 3 | -7/+7 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+2 |
| | | | | | * sp31/task1.c: Use PRIdWatchdog_Interval to print Watchdog_Interval's. | ||||
* | Use PRIdWatchdog_Interval to print Watchdog_Interval's. | Ralf Corsepius | 2009-10-26 | 1 | -6/+6 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+5 |
| | | | | | * sp20/task1.c, sp32/init.c, spclockget/init.c: Use PRIdrtems_interval to print rtems_interval's. | ||||
* | Use PRIdrtems_interval to print rtems_interval's. | Ralf Corsepius | 2009-10-26 | 3 | -5/+5 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+1 |
| | | | | * sp13/task1.c: Misc. uint32_t fixes. | ||||
* | Misc. uint32_t fixes. | Ralf Corsepius | 2009-10-26 | 2 | -11/+11 |
| | | | | * sp20/task1.c: Misc. uint32_t fixes. | ||||
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+4 |
| | | | | | | | * sp47/init.c: Add PRIXModes_Control, PRIXrtems_mode. Use PRIXrtems_mode to print rtems_mode's. * sp08/system.h: Add PRIxModes_Control, PRIxrtems_mode. Use PRIxrtems_mode to print rtems_mode's. |
