* | Added this file. | Joel Sherrill | 1999-02-10 | 1 | -0/+8 |
* | Insure that the same output occurs when multiprocessing is disabled. | Joel Sherrill | 1998-12-03 | 5 | -1/+41 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -5/+17 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -3/+35 |
| | | | | it work. | ||||
* | Fixed use of incorrect macro for minimum stack size. | Joel Sherrill | 1998-10-05 | 1 | -1/+1 |
* | IDLE task stack size now specified as a field in the CPU Table for all | Joel Sherrill | 1998-09-23 | 1 | -1/+1 |
| | | | | ports. | ||||
* | Under allcoated task stacks. | Joel Sherrill | 1998-08-03 | 1 | -1/+1 |
* | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 1998-06-12 | 3 | -7/+37 |
| | | | | The array is too long and needs to be shortened. | ||||
* | Fixed prototype of Fatal_Extension. | Joel Sherrill | 1998-05-04 | 2 | -18/+15 |
| | | | | Fixed interface to cofndefs.h for initial extension set. | ||||
* | Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirements | Joel Sherrill | 1998-04-27 | 15 | -0/+30 |
| | | | | more accurate. | ||||
* | Initial sets of user extensions now have memory allocated on the fly | Joel Sherrill | 1998-04-15 | 1 | -2/+1 |
| | | | | for them. | ||||
* | Increased stack size so test would run in debug mode. | Joel Sherrill | 1998-04-06 | 4 | -4/+5 |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -7/+7 |
| | | | | the CPU family name constants. | ||||
* | Corrected to indicate test cases which were skipped. | Joel Sherrill | 1998-03-03 | 1 | -2/+2 |
* | Modified to reflect new restrictions on mutex being released. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 |
* | Removed extra line. | Joel Sherrill | 1998-02-20 | 1 | -1/+0 |
* | Increased stack space to let test run to completion. | Joel Sherrill | 1998-02-20 | 1 | -4/+4 |
* | Increased stack space of tasks. | Joel Sherrill | 1998-02-19 | 1 | -1/+1 |
* | Increased stack size of initialization task. | Joel Sherrill | 1998-02-19 | 1 | -0/+1 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 167 | -167/+167 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Added test case for rtems_interrupt_catch checking that the pointer | Joel Sherrill | 1997-10-21 | 2 | -1/+11 |
| | | | | for the returned old_isr_handler was non-NULL. | ||||
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 168 | -336/+336 |
* | Added support for rtems_message_queue_get_number_pending. | Joel Sherrill | 1997-07-31 | 4 | -0/+21 |
* | Used macro instead of hard coded number. | Joel Sherrill | 1997-07-09 | 1 | -1/+1 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 168 | -840/+840 |
* | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 1997-04-07 | 4 | -69/+76 |
| | | | | warnings. | ||||
* | added ifdef to avoid warning for unused variable. | Joel Sherrill | 1997-04-07 | 1 | -2/+6 |
* | corrected integer only definitions of "FP CHECK" routines to eliminate | Joel Sherrill | 1997-04-07 | 1 | -3/+10 |
| | | | | warnings. | ||||
* | corrected printf format to avoid warning | Joel Sherrill | 1997-04-02 | 3 | -7/+7 |
* | _CPU_Trap_Table_area is now conditional based on whether or not | Joel Sherrill | 1997-01-08 | 1 | -2/+5 |
| | | | | the application requires rtems to allocate a trap table | ||||
* | added cast | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
* | extended Task_id and Task_name arrays to avoid indexing past end of array. | Joel Sherrill | 1996-09-17 | 1 | -2/+2 |
* | Added _Thread_Do_post_task_switch_extension variable. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 |
* | added cpu_time_budget field to Thread_Control and removed the global variable | Joel Sherrill | 1996-06-05 | 1 | -1/+0 |
| | | | | _Thread_Ticks_remaining_in_timeslice. | ||||
* | updated screen | Joel Sherrill | 1996-06-03 | 5 | -40/+34 |
* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 1 | -1/+1 |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | ||||
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 25 | -0/+50 |
| | | | | or rtems initialization table in configuration table | ||||
* | updates from Tony Bennett to correct calling sequences. | Joel Sherrill | 1996-05-24 | 2 | -0/+2 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 2 | -2/+4 |
* | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1996-04-22 | 1 | -14/+27 |
| | | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured. | ||||
* | The name of the test support routine pause was changed to rtems_test_pause | Joel Sherrill | 1996-02-22 | 10 | -36/+32 |
| | | | | to avoid conflict with the standard POSIX routine pause(2). | ||||
* | Dispersal of internal thread handler resulted in removal of some | Joel Sherrill | 1996-02-21 | 1 | -16/+11 |
| | | | | variables and renaming of others. | ||||
* | removed post switch extension | Joel Sherrill | 1996-02-13 | 3 | -3/+0 |
* | As part of implementing the new isr synchronization algorithm using a | Joel Sherrill | 1996-02-09 | 1 | -1/+1 |
| | | | | single enumerated set of states the set of event manager variables changed. | ||||
* | Added RTEMS API control structure to per task memory usage macro. | Joel Sherrill | 1996-01-19 | 1 | -1/+2 |
* | Increased stack size. | Joel Sherrill | 1996-01-19 | 2 | -2/+2 |
* | increased stack space | Joel Sherrill | 1996-01-17 | 2 | -2/+2 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 2 | -4/+4 |
* | typos fixed | Joel Sherrill | 1995-10-31 | 1 | -0/+5 |
