The Classic binary semaphores without a locking protocol
(RTEMS_BINARY_SEMAPHORE) could be released by everyone, e.g. in contrast
to the POSIX mutexes (all variants) or the Classic binary semphores with
priority inheritance or ceiling, there was no owner check in the release
path.
This behaviour was a bit unexpected and not documented. Add an owner
check to the release path. Update sptests/sp42 accordingly.
This change has nothing to do with the simple binary semaphores
(RTEMS_SIMPLE_BINARY_SEMAPHORE) which have no owner at all.
Update #2725
Remove superfluous support for simple binary semaphores. With this we
can get rid of the CORE_MUTEX_NESTING_BLOCKS variant.
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Close #2720.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
of this patch set.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Use _Objects_Get_local() for _Semaphore_Get_interrupt_disable() to get
rid of the location parameter. Move remote object handling to semaphore
MPCI support.
Replace _Thread_Disable_dispatch() with _Thread_Dispatch_disable().
Replace _Thread_Enable_dispatch() with _Thread_Dispatch_enable().
This is a preparation to remove the Giant lock.
Update #2555.
Replace _Thread_Get() with _Thread_Get_interrupt_disable() to avoid the
Giant lock.
Update #2555.
Use _Semaphore_Get_interrupt_disable() instead.
Update #2555.
Add _Thread_Change_life_locked() as a general function to alter the
thread life state. Use it to implement _Thread_Set_life_protection() as
a first step.
Update #2555.
Update #2626.
The priority inheritance and ceiling CORE mutexes wrongly used the FIFO
queueing discipline. Delete misleading _CORE_mutex_Is_priority(). Bug
introduced by 1e1a91ed11458ddbb27b94d0001d8f0fc2ef7a97.
Add test sptests/spmutex01, since no existing uni-processor test covered
the thread priority queueing discipline for CORE mutexes.
The _Objects_Information_table is statically initialized. So, we can
make it read-only.
Update #2494.
Update #2555.
Remove support for strict order mutexes.
Close #2124.
The mq_open() function returns a descriptor to a POSIX message queue
object identified by a name. This is similar to sem_open(). In
contrast to the POSIX semaphore the POSIX message queues use a separate
object for the descriptor. This extra object is superfluous, since the
object identifier can be used directly for this purpose, just like for
the semaphores.
Update #2702.
Update #2555.
Remove unused location parameter.
Add a lock and use a chain iterator for safe iteration during concurrent
user extension addition and removal.
Ensure that dynamically added thread delete and fatal extensions are
called in reverse order.
Update #2555.
Update #2692.
Add a chain iterator for safe iteration of chains with concurrent node
extraction.
This service was marked as deprecated long prior to the 4.11 release
series and is now being removed.
closes #2676.
POSIX key destructors must be called during thread restart. Just like
the POSIX cleanup handlers. This ensures that the TLS object
destructors are called during thread restart for example. It is
important for the global construction, which uses a thread restart to
run the Init task in a clean environment.
Close #2689.
Use a red-black tree to lookup active global objects by identifier or
name.
Update #2555.
Update #2555.
This field was only by the monitor in non-multiprocessing
configurations. Add new field Thread_Wait_information::remote_id in
multiprocessing configurations and use it for the remote procedure call
thread queue.
Add _Thread_Wait_get_id() to obtain the object identifier for debug and
system information tools. Ensure the object layout via static asserts.
Add test cases to sptests/spthreadq01.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Fix a block of off-by-one indentation and add braces to clarify
intention.
Use the default thread lock to protect rate-monotonic state changes.
This avoids use of the Giant lock. Split rtems_rate_monotonic_period()
body into several static functions. Introduce a new thread wait class
THREAD_WAIT_CLASS_PERIOD for period objects to synchronize the blocking
operation.
Close #2631.
This avoids a problem with the feature test macros introduced in Newlib
be657151f12f4d198e45395987f0a626ee1bbb91.
Use the object allocator lock in _Objects_Get_next() instead of disabled
thread dispatching since object creation and deletion is covered by this
lock.
Update #2555.
Create implementation header file.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
