* sp32/init.c: Lengthen the clock tick and move configuration to the
bottom of the file.
* Makefile.am, configure.ac: Add new test to exercise when the ticks
since boot wraps around 0 and the timer server must deal with that
condition.
* sp67/.cvsignore, sp67/Makefile.am, sp67/init.c, sp67/sp67.doc,
sp67/sp67.scn: New files.
* sp40/init.c, sp40/sp40.doc, sp40/sp40.scn: New test cases.
* spintrcritical09/init.c, spintrcritical10/init.c,
spintrcritical11/init.c: Fixed potentially infinite loops.
* sptests/spintrcritical09/init.c, sptests/spintrcritical10/init.c,
sptests/spintrcritical11/init.c: Fixed potentially infinite loops.
* sp20/system.h: Increased micro seconds per tick in order to be more
independent of the console output speed.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* sp54/init.c: Use rtems_build_id to make building Objects_Id
RTEMS_USE_16_BIT_OBJECT clean.
* Makefile.am, configure.ac: Add new test to exercise when notepads are
not configured.
* spnotepad01/.cvsignore, spnotepad01/Makefile.am, spnotepad01/init.c,
spnotepad01/spnotepad01.doc, spnotepad01/spnotepad01.scn: New files.
* sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen05.c,
sp09/screen09.c, sp09/screen14.c, sp09/sp09.scn, sp28/init.c,
sp28/sp28.scn, sp43/init.c: Add more error cases uncovered by uC5282
coverage runs.
* sp09/screen02.c, sp09/screen04.c, sp09/screen07.c, sp09/screen09.c,
sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/sp09.scn: Add
some error cases uncovered by uC5282 coverage runs.
* sp33/init.c, sp33/sp33.scn: Add some barrier error cases uncovered by
* sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c:
Correct minor issues uncovered on uC5282.
* sp04/tswitch.c, sp07/system.h, sp07/taskexit.c, sp07/tdelete.c,
sp07/tstart.c, spfatal_support/init.c, spfatal_support/system.h:
Eliminate use of deprecated rtems_extension.
* sp14/asr.c, sp14/sp14.doc, sp14/task1.c, sp14/task2.c: Adjust test to
run when IO speed varies.
* sp43/init.c, sp43/sp43.scn: Minor correction to test case so it hits
the intended code.
* configure.ac: Revert accidentally committed lines.
* Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very
simple priority ceiling case that was previously only tested via the
POSIX API.
* sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc,
sp66/sp66.scn: New files.
* sp43/Makefile.am, sp43/init.c, sp43/sp43.scn, sp43/system.h: Add test
for Id which is in range for the object class but not allocated yet.
* sp46/init.c, sp46/sp46.scn: Fix numbering.
* spintrcritical_support/intrcritical.c: Fixed timing rountines.
* spfatal01/spfatal01.scn, spfatal01/testcase.h,
spfatal02/spfatal02.scn, spfatal02/testcase.h,
spfatal03/spfatal03.scn, spfatal03/testcase.h,
spfatal04/spfatal04.scn, spfatal04/testcase.h,
spfatal05/spfatal05.scn, spfatal05/testcase.h,
spfatal06/spfatal06.scn, spfatal06/testcase.h,
spfatal07/spfatal07.scn, spfatal07/testcase.h,
spfatal08/spfatal08.scn, spfatal08/testcase.h,
spfatal09/spfatal09.scn, spfatal09/testcase.h, spfatal10/Makefile.am,
spfatal10/spfatal10.scn, spfatal11/Makefile.am,
spfatal11/spfatal11.scn, spfatal12/Makefile.am,
spfatal12/spfatal12.scn, spfatal_support/init.c: Make all fatal error
tests use testcase.h and spfatal_support framework. Print test name
herald in all cases.
* spfatal10/testcase.h, spfatal11/testcase.h, spfatal12/testcase.h:
New files.
* spfatal10/init.c, spfatal11/init.c, spfatal12/init.c: Removed.
* spfatal07/testcase.h: Indicate test is not applicable on some
architectures.
* Makefile.am: Fix spacing.
* spstkalloc/init.c: Changed allocator signature. Functions are now
static.
* sp29/init.c: Fixed return value evaluation.
* sp59/init.c: Added status code assignment. Fixed typos.
* sp59/init.c, sp59/sp59.scn: Added status code assignment. Fixed typos.
* sp63/init.c: Check return value of _Heap_Initialize().
* spwatchdog/spwatchdog.scn, spwatchdog/task1.c: Add test for
_Watchdog_Report() when name is not NULL. This case was covered at
-Os on erc32 but at -O2 we had more code.
* sp63/init.c, sp63/sp63.scn: Add case for math on size requested
overflowing on _Heap_Allocate_aligned.
* spobjgetnext/init.c, spobjgetnext/spobjgetnext.scn: Add error cases
for various null parameters.
* sp16/sp16.scn, sp16/task1.c: Fix typo.
* sp65/init.c: Remove stray print.
* sp65/sp65.doc: Add information on second case.
* sp65/init.c, sp65/sp65.doc, sp65/sp65.scn: Add new test case to
verify that obtaining a priority ceiling mutex when the calling
task's priority is the same as the priority ceiling is handled
correctly.
* sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c,
sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c,
sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c,
sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c,
sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c,
sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c,
sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c,
spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* sp65/init.c: Add semi-colon to end of rtems_semaphore_create call.
Change attributes to priority ceiling. Use directive_failed, not
assert. Configure a semaphore not a region.
* ChangeLog, Makefile.am, configure.ac: Add new test for some core
mutex cases.
* sp65/.cvsignore, sp65/Makefile.am, sp65/init.c, sp65/sp65.doc,
sp65/sp65.scn: New files.
* spintrcritical01/init.c, spintrcritical06/init.c: Use 1 millisecond
per tick.
* Makefile.am, configure.ac, sp62/init.c, sp64/init.c: Add new test and
adjust existing for alignment. New test ensures coverage begin and
end marker methods are exercised so they do not get considered
unexecuted.
* spcoverage/.cvsignore, spcoverage/Makefile.am, spcoverage/init.c,
spcoverage/spcoverage.doc, spcoverage/spcoverage.scn: New files.
* Makefile.am, configure.ac: Add new test to exercise legacy
rtems_clock_get().
* spclockget/.cvsignore, spclockget/Makefile.am, spclockget/init.c,
spclockget/spclockget.doc, spclockget/spclockget.scn: New files.
* sp04/task1.c, sp09/screen02.c, sp09/screen04.c, sp09/sp09.scn,
sp38/init.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* sp01/sp01.scn, sp01/task1.c, sp03/task1.c, sp03/task2.c,
sp04/task1.c, sp04/tswitch.c, sp09/screen02.c, sp09/screen13.c,
sp09/screen14.c, sp09/sp09.scn, sp11/sp11.scn, sp11/task1.c,
sp11/task2.c, sp19/fptask.c, sp19/sp19.scn, sp19/task1.c,
sp22/prtime.c, sp22/sp22.scn, sp22/task1.c, sp24/sp24.scn,
sp24/task1.c, sp30/task1.c, sp31/prtime.c, sp31/sp31.scn,
sp31/task1.c, spwatchdog/prtime.c, spwatchdog/spwatchdog.scn,
spwatchdog/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* sp28/init.c, sp28/sp28.scn: Update screen. Add a few missing error
cases.
* sp64/init.c, sp64/sp64.scn: Chris ensured that nothing is moved until
all memory is successfully allocated. This means the test can
validate the heap is unchanged on extend failure.
* spintrcritical01/init.c, spintrcritical06/init.c,
spintrcritical08/init.c, spintrcritical13/init.c: Lower microseconds
per tick so tests run quicker and more reliably hit the intended
critical section.
* Makefile.am, configure.ac, sp63/init.c: Add new test for exercising
when we are unable to allocate the memory needed for an object
extend. Make sure all is handled properly.
* sp64/.cvsignore, sp64/Makefile.am, sp64/init.c, sp64/sp64.doc,
sp64/sp64.scn: New files.
* sp63/init.c: Correct test case two.
* sp63/init.c, sp63/sp63.scn: Move into subroutines and add a second
test case to exercise another odd branch not taken.
* Makefile.am, configure.ac, sp62/init.c: Add new test to ensure a
particular path is taken through the _Heap_Resize_block code.
* sp63/.cvsignore, sp63/Makefile.am, sp63/init.c, sp63/sp63.doc,
sp63/sp63.scn: New files.
* sp42/Makefile.am, sp42/init.c, sp42/sp42.scn: Test was testing the
wrong thing in a cpp macro. Added contents to screen file and add
documentation file.
* sp42/sp42.doc: New file.
* spintrcritical16/spintrcritical16.doc: Remove junk and typos.
* spintrcritical16/init.c: Tinker with test to make it hit the case
more reliably.
* Makefile.am, configure.ac: Add new test to exercise as many cases as
possible of not being able to allocate memory from the workspace
during thread creation.
* sp18/.cvsignore, sp18/Makefile.am, sp18/init.c, sp18/sp18.doc,
sp18/sp18.scn: New files.
