#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Do not use _TLS_Size here since this will lead GCC to assume that this
symbol is not 0 and the later > 0 test will be optimized away.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
