path: root/testsuites/sptests/sptimecounter02 (follow)
* testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-20/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* Rename CONFIGURE_SMP_MAXIMUM_PROCESSORSSebastian Huber2017-02-141-1/+1
| | | | | | | Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS since the SMP part is superfluous. Update #2894.
* Remove CONFIGURE_SMP_APPLICATIONSebastian Huber2017-02-021-2/+0
| | | | | | Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1. Update #2893.
* sptimecounter02: Add plot scriptSebastian Huber2016-12-081-0/+42
* sptimecounter02: Update screen fileSebastian Huber2016-12-081-32/+986
| | | | Data obtained on QorIQ T4240 running with 1500MHz.
* Provide kernel space header filesSebastian Huber2016-11-081-0/+2
| | | | | These kernel space header files must be provided for Newlib 172e2050d95b41861db858dd9bc43a3fb4a28987.
* timecounter: Use in RTEMSAlexander Krutwig2015-05-204-0/+346
Replace timestamp implementation with FreeBSD bintime and timecounters. New test sptests/sptimecounter02. Update #2271.
