* sptests.am: Set project_bspdir=$(PROJECT_ROOT)
* sptests.am: Remove LIB_VARIANT.
* sptests.am: Add dirstamp support.
* sptests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* sptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* sptests.am: Remove DEFS.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
