#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Due to structure internal padding the use of memcmp() may lead to
sporadic test failures.
Update #3082.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #2825.
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
This define accidentally re-appeared.
This fixes a copy and paste error (from libbsd).
This mutex implementation uses a thread priority queue with a simple
priority inheritance mechanism (similar to the object based mutexes).
The storage space must be supplied by the user (16 bytes on 32-bit
targets).
