Updates #3053.
Updates #4625.
Avoid a dependency on errno which might be a thread-local object. The tests
sp01, spstkalloc02, and sptls03 assume that no thread-local storage object is
present.
Update #4560.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Close #2895.
Avoid collision with <sys/param.h> defined PAGE_SIZE.
Move implementation specific parts of heap.h and heap.inl into new
header file heapimpl.h. The heap.h contains now only the application
visible API.
for details.
PR 1924/cpukit
* spstkalloc02/.cvsignore, spstkalloc02/Makefile.am,
spstkalloc02/init.c, spstkalloc02/spstkalloc02.doc,
spstkalloc02/spstkalloc02.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
